Question about Refrigerators
Motor is making a horrible grinding sound - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 29, 2010
My frigidaire fer231cas2 makes a horrible loud GRINDING noise after its been running for 10 or so mins
Hello friend, thank you for your post!
I see that you have changed multiple parts within your Frigidaire dryer due to a grinding noise. Since you have changed the bearing cup, felt, pulley, and belt I would recommend having a technician come out to diagnose your appliance to avoid any further unnecessary part purchases. You could be seeing an issue within the drum or motor. I hope this information is helpful. -Matt
Aug 26, 2014 | Frigidaire Dryers
Mitre saw makes horrible noise
  • It sounds like the bearings in the motor are running dry and causing the noise. Possibly spray some wd40 in there but more than likely you will need a new saw. Is it still under warranty? If so take advantage of your warrant.
Jul 05, 2014 | Dewalt Mitre Saw Workstation
First the door wasnt releasing to shut with the power button, now its not doing anything and the motor is making a horrible grinding sound
It sounds like the motor gears are stripped or the cable has broken . You will need to remove the door trim to investigate and repair/replace the unit.
Jan 12, 2014 | 2007 Dodge Grand Caravan SXT Minivan
MY OSTER 5838 EXPRESSBAKE BREADMAKER MAJES HORRIBLE GRINDING SOUNDS WHEN MIXING
You may have a bearing problem causing the grinding noise or the motor stator is rubbing on the housing
Jan 01, 2012 | Oster 5838 ExpressBake Bread Maker
1998 Toyota Corolla - Heat doesn't work - just makes a horrible grinding sound when turned on but doesn't blow at all.
Check blower motor unit for ice build up. If all clear your blower motor needs replacing. I would recommend a service shop to do diagnoses.
Feb 18, 2011 | 1998 Toyota Corolla
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Sep 12, 2010 | Maytag Dryers
Rear-end grinding noise in 1993 GMC Sierra 1500
your description sounds like the gears inside the the same differential you just replaced.
Oct 13, 2009 | 1993 GMC Sierra K1500
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
