Question about Vacuums
I HAVE YOUR UNIT MODEL CD1493. THE POWER CORD PLUGS INTO THE BACK OF THE UNIT OK,BUT, IT A VERY WIGGLY CONNECTION. AS A RESULT THE UNIT OPERATES VERY INTERMITTENTLY. WHAT CAN I DO.
  • 43,501 Answers
Try to spred the pins slightly so that they hold the plug more tightly...otherwise the only thing to do is to try and buy a replacement cord...
heatman101
Posted on Aug 29, 2010
Where is the reset button on the kirby sentra
I'm not aware of any "reset" button. If the vacuum does not turn on, it's usually due to one of the accessories not being installed properly.
From the manual:
"IF THE MOTOR DOES NOT RUN WHEN THE MOTOR ON-OFF SWITCH IS PUSHED:
1. Make sure the Power Cord is plugged into an outlet and that the outlet has power. (Check for a blown fuse, tripped circuit breaker or power company trouble.)
2. Make sure the cord plug is fully inserted into the unit.
3. Look for breaks in the Power Cord insulation. If the cord is damaged, get a new one. DO NOT ATTEMPT TO REPAIR IT. Use only a genuine Kirby® Power Cord. Do not use standard extension cords.
4. Make sure that an attachment or accessory is properly mounted on the front of the Power Plant. The unit will not run without the Power Nozzle , Hose Coupling, Air Intake Guard or Accessory Brush Nozzle in place.
5. The unit will not operate without either a Filtration Bag Assembly/ Mini Em-Tor® collector ?, Attachment Hose or Carpet Shampoo Tank properly installed on the Air Exhaust Port ?.
6. The Filtration Bag Assembly/Mini Em-Tor collector, Attachment Hose or Carpet Shampoo Tank must "click" firmly into place for the unit to operate. If the fitting is too tight and you have difficulty installing the above, apply a small drop of water to the gasket to reduce friction and ease installation.
Here's a link to the owner manual if you lost yours:
http://kirbywhq.powweb.com/manuals/se2/45B6BEDE315CBA7174350751ECA71E5D/LV-260012-E%20Domestic%20Manual.pdf
Feb 09, 2018 | Kirby Vacuums
Electrolux canister, maybe fifteen years old, green light indicating cord is plugged in is not lit, nor will the the vacuum turn on. Model 2100 Omni-flow automatic, number on bottom of unit F14970F. Thank...
The light indicates the vacuum is getting power, not only the cord is plugged in. If there's a break in the cord, other wiring, or bad connections, the light will also not light because the vacuum isn't getting power.
Have it checked over at an authorized Aerus Electrolux shop. The service tech can diagnose and tell you the problem, as well as provide an estimate. There should be no charge for this.
Use the below link to find the store nearest you.
http://www.aerushome.com/storelocator/
Mar 16, 2011 | Vacuums
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Power head attachment works great when plugged into the hose part of the vacuum. The problem is when I attach it to the tube for normal use there is no power. I have checked all the connections and...
try having someone turn the machine on and off while you pull the cord in and out with the cord more angled towards the on/off switch. Sometimes these models have a break in the cord rewind and will not put the power through to the motor.
Keep in mind this is repairable, and if the unit is less than 5 years old it should still be under warranty.
Good luck .
Nov 19, 2010 | Miele Vacuums
Having trouble with electrical cord.
Greetings from GoVacuum.com,
I'll tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores2_bing.gif. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
GoVacuum.com
May 12, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Generation 3 no power...
I don't believe there are any service manuals online, as Kirby has service centers around the country. There are 3 things in the power string--on/off foot switch, the power cord, and the power assembly that the cord plugs into underneath the bag in the main part of the body. One of the problems the G3 had was where the cord plugged into the body--the assembly was a very thin plastic piece supporting the 2-prong electrical connection. This plastic piece was known for breaking, and was actually recalled back in the 90's. You can take the cord connection off and look to see if that piece is broken, then you'll have to take it in, or buy a "switch" as it's called on ebay or somewhere and replace.
Dec 29, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Power on
Hello markswifey92. Check your AC cord & plug. There maybe a wire broken. Be careful of exposed wire. #2 May be a bad power switch. Please inform me of the results and I will provide repair steps. Please include Mgfr, model & serial#. Good luck.
Sep 27, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Was vacuuming fine and suddenly the thing won't turn on. Tried another plug.
Same thing happened to my Wertheim 4030. It turned out to be a broken connection in the retractable cord plug, no doubt due to continual shock upon retraction. How did I find it? By pulling the top off and first checking the internal switch was working with an ohmmeter (definitely no power for this test) Then plugged in, powered up & checked if any power to switch with AC voltage tester(be careful and have unit RCD protected for your safety) None showing, so checked if power at internal reel. None, so switched off power and checked continuity of cord for active and neutral continuity. None in one so cut off plug and checked again OK so new plug fitted and reassembled. If I had power to the switch originally, the motherboard/rheostat or motor may have been the problem. Hot wiring the motor would have determined which(unlikely to be both but a possibility) Repair or replace faulty item, obviously checking motor brushes first. Electrical is simply a matter of isolation and elimination.
rjjs
May 16, 2008 | Hoover Vacuums
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
