Question about Kodak Cameras
I have a Kodak M1033 and sand got inside of it. I tryed blowing all the sand out but when I try to turn it on the screen it just black or it flashes blue and says camera #E12 see user guide. The lens is also all the way out and won't go back in. Is it possible to fix?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 29, 2010
I dropped my camera, and the lens wont close. When i turn it on, the screens blurry. It sounds like its trying to focus, and then it shuts off. I just want to know if its fixable??? Or should i just buy...
Focusing mechanism might be either broken and jumped out of its place
1) Take a screwdriver and open it yourself (it's not that complicated, as soon as you don't lose any parts; just try to remember where every part lies in).
2) When after opening the case you still don't understand how the focusing mechanism functions try to place battery inside, switch it on and then you'll see what exactly is blocking the focuser from moving back and forth.
3) Either place the focusing mechanism back correctly or if something is broken that you can fix with a SuperGlue - do it.
P.S. I once had the same problem after dropping my photo camera (Canon PowerShot G7), but the focusing mechanism was broken so had to go the mechanic to replace it. Mechanic normally wouldn't object that you have already disassembled the camera - less work for him.
Mar 05, 2011 | Kodak EasyShare M1033 - black Digital...
Kodak m1033 lenses stuck 'open'. Camera won't power on, just beeps and turns off when powered on. Camera froze when zoomed out max, removed batteries and now camera is stuck.
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 14, 2010 | Kodak EasyShare M1033 Digital Camera
My kodak easy share m1033 camera turns off when i press any button
there is dirt or sand in motorized lens turn camera on and pop battery out before lens goes back in. Use a lens cleaning cloth and wipe all the outside of the camera lens well I also use a can of air and blew the three rings of the lens.I had to do this two times but now the camera works great
Mar 23, 2010 | Kodak EasyShare M1033 Digital Camera
My lens focuses only intermittenly
If you have the settings on AUTO the camera will automatically adjust to what it thinks will make the best picture.
Try and use the SCN.
You can also switch the flash on and off as you wish.
For more tips and tricks on picture taking please follow this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=38/13915/39&pq-locale=en_US
Jan 02, 2010 | Kodak EasyShare M1033 Digital Camera
Its turns on beeps then shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 05, 2009 | Kodak EasyShare M1033 - black Digital...
Cam keeps shutting off, no picture turns off immed.
Try new batteries fully charged if this dose not do the trick cash in on the warranty and have then get you back on track
Jul 27, 2009 | Kodak EasyShare M1033 Digital Camera
My Kodak EasyShare M1033 will not auto-focus. I was using it on vacation with no issues for 5 days and all of a sudden it won't focus. I did online chat with the Kodak helpdesk but he had no clue. This is...
Try to set the camera on auto mode
make sure that the flash is also set in auto
take pictures in different lightning condition out door and in door
if the problem still persist its either the lens assembly or the camera sensor is defective
Jun 14, 2009 | Kodak EasyShare M1033 - black Digital...
When I turn on my Kodak EasyShare M1033 the screen is black.
"My sister thinks it's probably because I dropped it to much (which I do)"
"I even smacked it a couple of times."
Simple NEVER buy another camera again!
Mar 22, 2009 | Kodak EasyShare M1033 - black Digital...
Cameras Logo
99 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
