Question about Refrigerators
We moved a refrigerator to the garage. it has power (lights are on) but the refrigerator will not turn on to cool down.
  • 21 Answers
Thermostat open circuit. replace thermostat
Posted on Sep 01, 2010
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Hi, I bought this Roper Refridgerator at a garage sale, it was going to be a beer/bait freezer for the garage, looks really nice, and was told it worked. Actually it does have the light on and air is...
Hi. Let it sit unplugged for 24 hours after moving it. That will allow all of the compressor oil to settle. Then plug it in and expect it to take another 24 hours to cool. If it does not cool, it is probably low on refrigerant, an easily remedied problem. J.
Aug 10, 2010 | Refrigerators
We have it in a summer home where power is off during the week. On the weedends, we turn on power and our fridge worked fine for the first month or so. Now the refrigerator portion does not cool down but...
the freezer takes first priority for cooling,then the fridge,the unit will take about 24 hours to reach optimum cooling even with the fast freeze button on.we used to have unit in garage with power on to unit permanently.using a power breaker in case of shorts etc......(f/f are supposed to be on permanently)
Jun 29, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Fridge not cooling
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost. If there is, then you need a new defrost timer, defrost heater, or defrost terminator.
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
These are the most common issues.
Let me know if everything looks ok and I will go over some other things, as the list of things that can go wrong with a refrigerator is fairly long.
Dec 07, 2008 | Refrigerators
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerator power is on, but is not working
I don't really understand the question. the outside temp. should have nothing to do with the inside temp, except for efficiency on the bill. You do have gaskets on the doors, right?
Dec 17, 2007 | Refrigerators
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
