Question about KitchenAid Dishwashers
NSF Residential Dishwasher green lights on, will not accept commands. Turned off electricity supply and restarted, no change.
  • 1 more comment
  • myngbl Aug 29, 2010
    Rylee,
    The buttons are different on my machine.
    From left to right they read:
    Heavy Duty, Normal, light/chine, quick clean up, rinse only, pro scrub, high temp scrub, sani rinse, heat dry, 4 hour delay.
    Hope this helps,
    Annette
  • myngbl Aug 30, 2010
    the green lights are flashing on 'cancel' and 'normal'.
    The model is KUD802FRWHO
  • myngbl Aug 31, 2010
    Didn't work. Model Number KUD802frwho
  • 1,531 Answers
You need to replace the control board
Posted on Aug 31, 2010
  • KitchenAid Master
  • 909 Answers
When that scenario starts, replace the board. The program on the micom. is corrupt. Oper up the panel door and unscrew the 8 screws holding the outer panel. You will then see the control module. Look for a sticker on the controller and quote that number with the dishwasher model no. when ordering the new part. (Make sure plug is pulled out of socket when opening the door panel).
  • KitchenAid Master
  • 3,247 Answers
It would help if you provided the actual model no. of your dishwasher. NSF is only a rating of the dishwasher and not the model.
Also please confirm if the green lights are on or flashing.
In the meatnime you can also check this problem reported on fixya recently to see if the solution helps.
Posted on Aug 30, 2010
  • Sam Aug 31, 2010
    I am thinking it is the door latch which is not sitting properly. This particular model you have is not covered in the KitchenAid website so I am assuming it must not be one of the newer models.
    The door switch is in the top of the door panel and will be either not making contact with the door close lever or the switch is faulty.
    Unfortunately I cannot direct you to the actual part as I am unable to track any site with your specific model no. Can you please recheck the model no. and confirm you have not dropped any letter anywhere. eg. KUDB... instead of KUD8 etc.
    Try to press the door tighter and turn the door lever to see if any difference.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this you will have to reset the console, press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • Rylee Smith
    Rylee Smith Aug 30, 2010
    Press these buttons in sequence to reset it:
    sani rinse, heat dry,sani rinse, heat dry
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Aug 31, 2010
    Then you'll have to replace the control panel
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
I have the Toshiba 72HM195 Rear Proj, sometimes when it comes on it is all green, restart it, and it is ok, now it is making a clicking soun d an d freezes
INDICATES a communication problem---set will not accept commands and this could mean a issue with the optical light engine.
May 14, 2012 | Televison & Video
Dishwasher will not start andthe green lights on control panel on front of dishwasher door blinking. I have look for obstructions and the door seems to shut good.
I have had this problem with a different make of dishwasher. The light came on but then it did not work.
It turned out to be the water had been turned off to the dishwasher.
Check your water supply is on!
Sep 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
My hp a6130n desktop computer won't turn on after a lightning storm. The power supply is good (the little green light in the back comes on) the switch is good - tested it, so I wonder what is wrong - is it...
i got the same problem accept it didnt involve lighting storm thunder when i turned it off then i try turning back on it would start any help seems like the motherboard is fine the lil green light on back is on also can figure the problem help plz?
Jul 06, 2009 | HP (D7580-60003) Motherboard
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Hobart LT 1 dishwasher leaving film on dishes
The machine is seldom the cause of "film". Make sure the unit is draining proper and that the fresh water supply is supplying good pressure.
Usually film is caused by using residential soap in a commercial unit. The commercial unit cycle is too short for residential soaps to dissolve and work properly. So soap ends up in your rinse water.
Mar 23, 2008 | Dishwashers
Dishwashers Logo
71 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
