Question about Whirlpool Dryers
My whirlpool dryer will start fine, and run for about 2 to 3 minutes then shut off. It heats up fine, and I have cleaned the filter and exaust pipe that leads to outside. Do you have any suggestions on what it could be? Thank you Michael
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Dryer slow to start. push button several times to get started. pulls heavily on electricity and causes 120 surge protectors to pop. any ideas?
are you overloading it with alot of wet cloths , you cannot put a ton of cloths in a dryer , try this first , make sure the filter is clean out ,and even the exaust pipe is not clogged either
Mar 07, 2015 | Estate by Whirlpool EED4400WQ Estate 29in...
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
We have a breckwell model P23fsl we just cleaned the exaust pipes the day before yesturday, it will start up, fans are running fine, it flames high orange flames, it acts like theres wind blowing the...
Sounds as if the gasket material on the door needs to be replaced. It's allowing to much air into the firebox, thus causing the flame up you're seeing. Or, the door just may not be closed tightly.
Hope that helps solve your problem.
Mar 06, 2011 | Heating & Cooling
My dryer runs about 30 minutes and then will shut off. After you give it a minute to it will turn back on but when it is in constant use it happens very frequently. It doesn't matter what heat setting it...
sounds like the safety thermostat (Hi Limit Thermostat) is cutting your dryer off. This usually happens because of hi heat (higher than normal) which is caused by clogged exaust.
Check your dryer vent to ensure that is is completly free of lint. Clean the lint from the lint trap all the way to the output of the exaust outside your dwelling, ensuring the dryer has a unobstructed flow of hot air.
R/Jim
Feb 16, 2011 | GE DBXR463EDWW Electric Dryer
Electric whirlpool dryer turns & heats but does not dry
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the section that discusses proper dryer ventilation. The fact that you don't see any lint collection in the lint trap could be a symptom of a dryer that is clogged, or an exhaust vent clog. An easy way of determing whether or not the problem is with the dryer, or the ventilation, is to remove the exhaust vent line from the back of the dryer and attempt to dry a load as normal. The air flow coming from the back of the dryer should be forceful and warm (about 140 degrees). If this is the case, the problem is NOT the dryer and may be attributed to something in the ventilation ducting from where it leaves your dryer to where it exits your home. An inspection of the vent ducting should be done to confirm it is clear and free of clogs or kinks.
If the air flow is weak, then you have a clog INSIDE your dryer. An inspection of the dryer blower fan housing should be done to ensure the fan is turning unobstructed and there are no clogs. If the air is cool, you probably have a failed component in the heating circuits.
Read through the link I provided and let me know if you have any questions. I hope this helps you.
Jun 22, 2009 | Whirlpool LER4634J Electric Dryer
Heat cycle stops/
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
part nos 694540 and 694539
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer shuts off after minutes, until cools down
have you cleaned the filters on it. it might be the thermostat if you have. or checked the outlet pipe for excess fluff.
Mar 26, 2009 | Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
DRYER SHUTTING OFF BEFORE CLOTHES ARE DRY
What you obviously have is a blocked filter housing. Get it off and wash it down. Clean out the dryer and open the vent.
Dec 11, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
