Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
What do i use to clean the copper cells - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • 297 Answers
Soak the unit in vinegar. cap off one end the cap came with the unit
let soak for 6-12 hours
check your salt level sounds like you have too much in the pool
get salt to 3000ppm
Posted on Aug 30, 2010
Why do i continue to show low salt?
I do have the same problem every few days all I just discover is that I remove the cell tube and with the help of a long thin knife I clean the surface of the copper cell both in between and outsides. There is always dry salt on the surfaces and after the cleaning the sensor reading is in acceptable level so the chlorinator is working perfect without any 91 massage. To work it every day in order to avoid this happens very often and of course every time you hear the beap sound you have to repeat the scrutching and cleaning with the nife,
Jun 13, 2014 | Intex Automatic Salt Water System for ...
My electrolytic cell and hose have bright aqua chalky feeling substance in them, what should I do and why is this happening?
you have some metals in your water and the cell needs to be cleaned. Aqua color Normally means Copper.
Did you use a Copper Based Algaecide?
Clean out the cell with a high pressure nozzle on the garden hose and a little bit of vinegar splashed on the cell before rinsing.
Aug 25, 2013 | INTEX Sand Filter Pump
How can I clean/polish copper cabinet hardware
If you want to clean or polish your copper cabinet hardware, there are few way to go, like cabinet hardware (Knobs & Pulls) which you believe are copper it's really zinc casting with copper plated.on which is applied a thin coat of polish to prevent oxidation, and that plate about two atoms wide and any sort of a harsh or chemical clean on it will wipe out it.
The finest thing you can follow is to take a jewelry polishing rag and go over the Cabinet hardware a bit. However, I don't see that it is offensive to have a copper pull that has turned color and has a "patina" on it. That is sometimes viewed as beneficial in decorating.
The zinc pulls with copper plating are made so after few years replaced with new pulls.
Mar 14, 2013 | Amerock Hardware & Accessories
How do i clean tarnished and oxidised copper
Copy following link:
http://www.wikihow.com/Clean-Copper
If you have old copper penny, or antique copper kettle, then do not clean since that will diminish value.
Nov 14, 2011 | Home
How do i clean off the salt accumulation on the plate?
Disconnect the 2 hoses from the saltwater system, and put on the cell cover plates. In a counter clockwise motion, unscrew the collar of the copper electrode and remove the electrolytic cell. Pour kitchen grade vinegar into the cell to immerse the titanuim plates, put the copper electrode back and soak for 1 hr + untill no color remains. then drain vinegar and reconnect
Jul 11, 2011 | Intex Automatic Salt Water System for ...
Cant get soder to hold on copper pipe soder flakes away doesnt stick
make sure joints are clean and sanded,flux-use mapp gas in torch burns hotter then propane,needed for 95/5 solder preheat up and down pipe for a few inches then do joints,keep you torch moving around joints it'llget a silver color then its ready.Don't get to hot or it will burn up flux.ps no water in the line or you'll never get it,cleaning pipe and fitting is most important
Jan 28, 2011 | Nibco Reducing Tee Copper X Copper X...
Fridge is not cooling blower is running but no cold air
1> check that there is a leakage in copper pipe or compressors just behind of the fridge in lower compartment cell.
2> you have to refill cooling gas neon again in compressor cylinder.
3> copper pipes attached with compressor may be jammed,please detach them properly ,clean their tunnels and then again attach in their respective positions.
4> check the door of the fridge lock properly on the fridge's wall or not,there must not be any gap between the contact surfaces of the door and the fridge;s wall.
now , your problem is solved, enjoy,Bi
Nov 29, 2009 | Televison & Video
My niece brush her teeth and left the toothpaste waste on my copper sink overnight - the next day everything obsorbed into the sink - how to fix it?
  • Polish with Bar Keepers Friend and fine steel wool. Use plenty of elbow grease. Keep the kettles extra bright by washing well with soap and water after polishing.
  • Dip half a lemon in kosher salt and rub well. Then polish with a soft cloth and beeswax for a deep, lasting copper shine.
  • Table salt and vinegar remove oxidation from copper.
  • To clean a copper kettle or boiler, you need to remove soap scum and hard water deposits as well as oxidation. Although a lightly oxidized copper piece can be cleaned with salt and lemon or vinegar, steel wool or a buffing wheel are required for heavy-duty copper cleaning.
  • Once your piece has a good shine, spray with a brightening product to maintain the clean, bright finish. Dust occasionally and wipe down with a cold, damp cloth.
hope i helped
Jul 24, 2009 | West Brass Antique Copper Kitchen Sink...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
262 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
