Question about GE JBP24 QuickClean Electric Kitchen Range
My house was hit by lightning. Hit my PC, 2 TV's, 2 DVD players, 2 VHS players, 2 Satillight boxes, Refrigerator,Sterio (dvd, tape, radio), and I think it hit my KitchenAid-Selectra glass top self clean-glass stove top-range. How would I know for sure it hit my range? There is a burnt rubber smell when I use it. Please help me quickly, I have to turn this clamim-paper work in tomorrow. Thank you so very much. Cheryl
  • 139 Answers
The only way to tell is to inspect the wires and switches ...unplug range remove the back panel to inspect all wires an connections .use a flashlight to see better ..let me know an good luck../joe/
Posted on Aug 30, 2010
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Can i transfer vhs to dvd
I haven't been able to use my Emerson EWR20V4 for a long time, but as I recall, the easiest way is to cue the tape to your desired starting point, pause, then hit the record button on the panel's DVD side, let it spool up & start recording, then unpause the tape. If desired, I think you can hit the DVD record button again to set 1/2-hr. increments before the recording will stop.
Apr 17, 2014 | Emerson EWR20V4 DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
We had a lightning strike which hit the house phone wire and knocked it out. the tv and dvd player didn't get hit. we turn the dvd player on it plays but no picture. the input button on remote won't switch...
Check the TV internal fuse. If fuse is OK check the SMPS. Lightning damage could harm any part and step by step only it can be found.
If you have insurance for your TV and other appliances, you can claim.
Better contact the authorised service provider for assitance.
Aug 27, 2010 | Zenith DVB712
Record Commercial Tape to DVR for personal use
Put tape in. Make sure the plastic tap isn't broke on front of vhs tape, if so, put tape over it.
Put tape and vhs in player, turn vcr channel to 04 I believe. Then hit the copy button. Otherwise put on dvd/ hit copy button
Dec 12, 2009 | Toshiba DVR620 DVD Recorder/VCR
I want to copy my VHS tape to a DVD
you should just have to hit the dubbing button on the front of the unit. Make sure you hit stop on both the vhs and the dvd sides. I found that in certain conditions it won't dub.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD-V3500 DVD player works fine the VHS does not display
Its problem of dirty / clogged video heads and can be solve by using VHS video head cleaning cassette.
Regards,
Sep 14, 2008 | Samsung DVD-V3500 DVD Player/VCR
Help w/ panasonic burner
I own one and it is a pain to work. Put in the disc and vhs tape and hit the bottom right button, I believe it says DVD and above it says dubbing. Hold it for a few seconds and the screen will come up and the system will do the rest recording from your VHS tape to the disc. You MUST finalize the disc after you are finished if you want to watch it in another DVD players if not it will only work on the Panasonic. Hope this helps. If not here is the site for the owners matual http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=54
Dec 06, 2007 | Panasonic DMR-E75V DVD Player/VCR
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
GE JBP24 QuickClean Electric Kitchen Range Logo
101 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
