Question about Char-Broil Patio Caddie 4654870 (LP) Grill
Last night the patio caddie by CharGrill wouldn't get hot enough (past 250F). Today I can't get any flame even with a new cylander. When you turn on the gas and the regulator, I used to hear a hissing sound, not anymore. I took the regulator (the valve part) apart and put it back, seems to be turning the valve normally; so unless something is clogged I am not sure why no gas is getting past the regulator.
  • 43,501 Answers
The regulator can and will go bad... it sounds like that is your problem...don't try to fix it that can be deadly...buy a new one...
heatman101
Posted on Aug 29, 2010
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
Patio heater goes out
If your patio heater goes out when you turn on the pilot and let go, this is usually a worn thermocouple. They last between 1 year (if you are unlucky) up to 6 years and are a consumable item. Found this site very useful patio heater problem solving.
May 24, 2012 | Dayva HS041 (LP) Open Flame Gas Patio...
The pilot goes on but when i un-depress the gas knob to turn the burners on it goes out..hence no flame. what's teh problem?
Generally this is caused bu a worn thermocouple, these last form 2 years up to 6 years but will wear out at some point. For help see patio heater problem solving, these patio heater specialist have helped me in the past.
Mar 03, 2011 | Endless Summer Blue Rhino 235000...
Does the Char Broil PAtio caddie come with bricquets?
No, it does not. Here is the complete parts list for your patio caddie:
Patio Caddie Parts
  • Electric Patio Caddie Heating Element
$22.00
  • Patio Caddie Ignitor Electrode
$4.19
  • Patio Caddie Burner Shield - Heat Distribution Plate
$10.75
  • Single Pole Snap-In Ignitor Push Button
$5.25
  • Patio Caddie Ignitor Wire
$2.50
  • Patio Caddie Top Lid Handle
$10.50
  • Patio Caddie Hardware Kit
$8.15
  • Electric Patio Caddie Aluminum Top Insert
$37.50
  • Electric Patio Caddie Aluminum Bottom Insert
$37.50
  • "Grease Catcher" Hanger Wire and Cup
$4.50
  • Patio Caddie Cooking Grate
$29.00
May 17, 2010 | Grilling
Char broil patio caddie, how many coals should it contain?
Your referring to the 'LAVA ROCK' which lines the botton grate. There should be enough to cover the grate 1 layer deep only.
Apr 27, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Grill with a full tank of gas will not get hot
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Char-Broil Patio Caddie 4654870 (LP) Grill
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Char-Broil Patio Caddie 4654870 (LP) Grill Logo
248 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
