Question about Sony VAIO PCG-K35 Notebook
Sony Vaio Laptop Battery - increase charge
I cannot find any instructions to help me increase my battery charge from 50% to 100% so the battery will last longer when I use it without plugging it in. I don't mind keeping the battery plan "Balanced" when I am using the ac/dc. How do I increase the battery charge to 100% before I must use it as a portable?
    Scholar:
  • 144 Answers
Hi Sony battery,
did you mean to say that you battery only remain at 50% and never exceed this amont ??
Normally all the notebook if you keep charging it should come up to 100%, but only a few case that will face the problem
1.problem with battery itself.
2.problem with ac adapter (I face very much problem here not continues power suplly)
3.problem with motherboard the module that deal with charging battery.
Goodluck,takecare.
Posted on May 08, 2008
Battery in my VAIO not recognized
The battery may be dead. How old is it? A battery has a "lifecycle" of sorts, just so many charge/discharge cycles.
Dec 27, 2012 | Sony VAIO Notebook
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
HI IAM USING SONY VAIO LAPTOP VGN SERIES NR11Z/T WITH MODEL NO.PCG-7Z1M. MY LAPTOP DOESNT USE THE BATTERY WHEN I CAHRGE. PLEASE HELP ME. IAM FACING TROUBLE AS I WILL HAVE TO ALWAYS CONECT TO POWER IF I...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 12, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
How to reset bios password on sony vaio laptop?
Please open you vaio laptop from bellow instruction link.
http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
Follow step 14
You can manege the idea about CMOS battery.
http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
Follow step 11
But this is your actual model
http://www.insidemylaptop.com/?s=PCG-K33+PC+Notebook
Just remove the Cmos battery And wit 2 minutes again fit the battery .Your password will be soon reset.
Hope it will help you.
Dec 26, 2010 | Sony VAIO PCG-K33 Notebook
I just bought a new battery and my laptop will not charge it?
1.refix the battery
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 17, 2010 | Sony VAIO VGN-T350P/T Notebook
Sony vaio won't charge new battery
i believe it is a charger issue not a battery issue replace your charger
Apr 08, 2010 | Sony VAIO VGN-CR410E/W Laptop
Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Mar 14, 2010 | Sony VAIO VGN-FE770G Notebook
Laptop Battery Wont Hold Charge
change original battery. check dc jack charger.
Jun 02, 2009 | Sony VAIO Notebook
SONY VAIO BATTERY CHARGING
This is not a problem, this is a designed function to increase battery life. To adjust this, go to "vaio control centre", and then power management. Inside this is battery care, here you can adjust the settings or de-activate this function.
Firephox
Oct 06, 2008 | Sony VAIO VGN-A150 Notebook
How to install 2nd battery
Most laptops these days do not have a second slot for a battery. This laptop only uses one battery. You would be best off purchasing a second battery and charging it ahead of time.
Aug 10, 2007 | Sony VAIO GRZ660 Notebook
Sony VAIO PCG-K35 Notebook Logo
161 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
