Question about Electrolux Ovens
My Electrolux EDB872 gas oven has lost electrical power. The fuse at the plug is ok. I've read elsewhere about a "reset switch". Is there such a thing or an internal fuse that might have blown?
  • 1462 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
i suspect there is no fault with timer. there is an overheat stat usually on top of the oven but sometimes inside the back. if this detects overheat, then everything is switched off and comes back on after cooled down.
if this is the case, then suspect lack of ventilation causing the overheat or the casing cooling fan failed.
get back to me if i got it wrong
Posted on Jul 18, 2008
  • 3 Answers
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Posted on Jan 15, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
  • 25 Answers
SOURCE: Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
Posted on Apr 07, 2010
  • 1891 Answers
SOURCE: gas in oven wont come on,burners and broiler ok,
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Posted on Jul 16, 2010
Whirlpool gas range
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Jul 26, 2014 | Whirlpool Ovens
Oven not working
5.
6.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Mar 10, 2014 | Belling XOU252 Electric Single Oven
Oven not working
5.
THINGS TO CHECK:
the broil element
The bake element
Feb 11, 2014 | Belling Ovens
Electrolux 30" electric double oven
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Dec 31, 2010 | Ovens
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
Electrolux EOB 966 stuck in auto mode
Hi, try to switch it off at the main switch. Wait for 10 seconds, then switch the power back on, reset the clock, and you should be fine.
Cheers
Feb 12, 2009 | Electrolux EOB6696X Electric Single Oven
No power on the disply panel
replace the control clock its shot...you may be under warranty,,check the last page in owners manuel,,,
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Electrolux EOG7330 gas cooker - electric timer fails?
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Ovens Logo
62 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
