Question about Tappan TGF320 Gas Kitchen Range
Tappan 30 Series Range ignition system
My mother has a Tappan 30 Series Range, none of the ele. ignition starters will work and they went out during a storm. Is there a reset button or fuse to replace somewhere?
Thanks
Renee
    President:
  • Tappan Master
  • 2,651 Answers
No fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
Posted on May 08, 2008
Igniters not working, no clicking sound. Cannot light stove with match.
Greetings
If none of you top burners produce clicking then it's most likely your ignition module. They can completely die. look for small box on back of range. @$60 Sears Parts Direct.
Easy Fix
Feedback Much appreciated
Aug 05, 2011 | Tappan TGF657 Gas Kitchen Range
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
Tappan range, will not in oven mode, can jiggle wires and bang ongas valve and get it to lite, but will not fire up after cycling.
Easy fix. Replace the igniter. When the igniter gets weak it takes longer if at all for the bi-metal inside the safety valve to open. I could bore you with the details or show you a video I compiled which explains it: HERE
This page shows how the ignition system works: HERE
Jan 09, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
I have a series 30 Tappan Gas Range with a broiler pilot light that glows but does not light.
Either a weak ignitor or stuck valve. I tap on the valve with the plastic end of a screwdriver while it is glowing and if it lights the ignitor is weak. If not the valve is stuck and both should be replaced.
eric
Jun 30, 2009 | Tappan TGF657 Gas Kitchen Range
Oven controls
those failure codes usually mean the oven sensor is out of range or has an open circuit.
you can replace the sensor for about 50-75 bucks and that will allow the oven to heat properly again.
you wont need to do any reseting or clearing of the code, just fix the problem and that code will go away.
Jan 14, 2009 | Tappan TGF320 Gas Kitchen Range
Where to order igniters for burners on gas range?
hi thanks for the question just go to goggle and type in tappan .it will take you to an appliance store near you thanks the appliance doc
Sep 28, 2008 | Tappan Kitchen Ranges
Tappan oven Model#30-3649-23/04
My igniter's just starting going off by themselves and the won't stop ? What should I do????
Feb 10, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
300 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
