Question about Maytag Performa PAV2200
Maytag performa PAV2330AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...Pls help
  • c_vamsi Aug 29, 2010
    correction..model number is PAV2300AWW -Maytag performa
    Champion:
  • 274 Answers
Hmm is it draining?
Posted on Aug 29, 2010
    yes it is draining
  • plante3pups Sep 04, 2010
    Is the machine a top loader or front loader?
Maytag performa stops during agitate or spin
All washers have a safety switch on the on lid. There is usually a slot that a plastic pin goes into to activate the switch. These switches are high failure parts. The switch is located on the underside of the top deck. It should check 0 ohms when closed. You can also jump it but then it would NOT stop when the lid is open ie; during agitation or spin cycle ( a safety hazard).
Sep 01, 2012 | Maytag Washing Machines
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Feb 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
My maytag won't spin. The agitator moves but the
Sounds like the transmission is shot. Call a repair shop, or buy a new one.
Oct 21, 2009 | Maytag Performa PAV2200
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
Mar 15, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
220 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
