Question about Hotpoint HSS25GFP Side by Side Refrigerator
NOISE COMING FROM FREEZER SIDE? IS THIS THE EVAPORATE FAN MOTOR?
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
jmeredith
  • 417 Answers
SOURCE: Evaporator Motor & Fan
hi,
you can try to completely defrost the fridge by unplugging it for a day and put you groceries in another fridge, sometime ice dams build up in those and freeze next to the fan blades and cause alot of noise, if its squealing, then its the motor for sure, evaporator motors are usually pretty easy to replace once you study where its at, usually the whole top or bottom and back of freezer has to come out then the motor and fan are right there, keep the fan blade assembly because you put that on the new motor, be extremely careful once you have the bottom and sides out because the coils will be vulnerable to anything if you hit them go to www.sears.com and go to parts area, theres a sears repair store in our town , hopefully in yours or just call around, dont forget to unplug it! hope that helps
J
Posted on Jul 10, 2008
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: Fan noise in freezer of my GE side-by-side refridgerator
You don't have to worry about the ice and frost, Your heater does that for you Your heater comes on and defrost every day. You just need to tighten the screws and clean up the vent where the noise is coming from but I wouldn't worry about it. The temperature on your fridge and freezer is running optimal, You know the saying, if it ain't broke, don't try to fix it....just tap the vent covers every few days.
Posted on Dec 06, 2008
  • 22 Answers
SOURCE: Evaporator fan new but not working on samsung rs267lash
Check the defrost thermostat body and see if it has separated a little bit. I have seen the def thermo go bad and cause this problem about 6 times now.
Posted on May 12, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My frig. is not cooling
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Posted on Dec 21, 2010
Testimonial: "Thanks for giving me headsup on the possible defrost solutions, need to figure out if its possible to test if those parts are any good on my frig."
My whirlpool side by side fridge/freezer is making a loud noise while running.
If the noise is coming from inside, the evaporator fan motor (the fan motor that circulates cool air located in the freezer section) may be the culprit. If noise is on the outside, the condenser fan motor may be the problem. This is the fan motor that removes the heat from the refrigerator to the room.
Jun 14, 2015 | Whirlpool Refrigerators
Loud noise in fridge like fanwhen it boosts. cuts out when door opened
The loud noise is probably coming from the freezer/evaporator fan motor in the freezer compartment.
Contact an appliance service company.
Feb 26, 2010 | Samsung RS2578BB Side by Side Refrigerator
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
I have a HotPoint side by side refrigerator. Model # CSX22GAS, my ice is melting and in the freezer section there is a loud noise. as if the motor is running hard.
Below is a link courtesy of www.repairclinic.com, that shows the evaporator fan blade. This may have come loose from the fan motor shaft and may be striking the fan shroud or rattling on the motor shaft
A loose fan blade cause elevated temps. If the fan blade is loose, replace it, not repair it, to avoid further problems.
1. Evaporator Fan Blade:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-CSX22GAS-%3d%3di2611&PartID=2611
2. Evaporator Fan Location: Mouse over parts for illustration.
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Aug 13, 2009 | Hotpoint Refrigerators
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Hotpoint HSS25GFP Side by Side Refrigerator Logo
129 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
