Question about Maytag MSD2756G Side by Side Refrigerator
Clicking sound and will not cool - Maytag MSD2756G Side by Side Refrigerator
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 29, 2010
Greetings I have a defy fridge making a clicking sound after every 5 minutes but not cooling its a defy model c317
That clicking sound is probably the overload breaker cutting off the power to the compressor for some reason. It clicks in because it senses not enough cooling but clicks back off after a few seconds because of overload on the compressor for some reason. It tries over-and-over.
Your compressor has failed in some way or the expansion valve for the coolant is not releasing the pressure as designed. This causes high back pressure on the compressor and it can't push against it, so it stalls and draws high current until the safety breaker kicks out.
I'm wondering, does it not cool at all or is it cooling a little but not near enough?
Dec 05, 2016 | Refrigerators
How do I silence clicking sound from a a Fujitsu Mini-Split Wall Mount?
Try taking it off the swing function. Only clicking I can think of, louvers getting jammed???
Sep 20, 2017 | Heating & Cooling
Admiral side by side fridge freezer gc2227cgfw - not cooling and clicking on/off noise from bottom of unit - have pulled out to investigate was very dusty and vacc'd out loads of dust - but warm in bo
Leave the unit unplugged for at least 4 hours then plug it back up, if it still clicks and doesn't cool, the compressor is likely burned out. It sounds as though it just overheated and is tripping out on overload, it should restart and run fine if it didn't get too hot. Good Luck...
Mar 21, 2014 | Admiral Refrigerators
Edge star not cooling and clicking sound
the clicking sound may be the condenser fan. if the compressor is running, check to see if there is dust or ice blocking the air flow on the condensor or if the fan is moving slow. this will prevent cooling. remove any obstructions and replace the fan if necessary
Nov 24, 2013 | EdgeStar BWC90SSLT - 84 Can Supreme Cold...
I have a DeLonghi PAC-CT90 air conditioner, it works great and cools very well, however it's recently started this rattle or clicking sound that's constant and loud. It still cools wonderful, and the...
I couldn't find much online, but clicking sounds sound like relay issue
Here is a link for the owners manual if you don't have one, It wouldn't hurt to clean the filters on the unit, probably won't help the clicking problem,
http://homeappliance.manualsonline.com/manuals/mfg/delonghi/pac160.html?idRes=12778077
Aug 25, 2013 | DeLonghi Heating & Cooling
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its not cooling down even though I can hear the motor running
Jul 17, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Refrigerator not cooling, do not hear compressor
clicking sound is motor protector cuting out compressor drawing to much current replace compressor.
Oct 21, 2009 | Refrigerators
Doesn't cool
Check your thermostat setting. the clicking sound is probably the compressor un-loading.
If you set the thermostat higher, the compressor will not turn off too soon.
May 08, 2009 | Refrigerators
Clicking sound every minute of so?
that is the compressor kicking in and out, check the start relay.
Oct 13, 2008 | Whirlpool GC5SHEXNS Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
37 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
