Question about Lasko 2554 WIND CURVE Fan
Its not a problem. How do you clean this fan. There is alot of dust inside of the front grid. Is there a special way this front grid can be removed for cleaning? Thanks.
  • Lasko Master
  • 43,501 Answers
My experience is that the best way is to use the canned air like you would clean a computer keyboard with...trying to remove the grille will result in broken tabs and then you have to tape it back on...
heatman101
Posted on Aug 29, 2010
Just use canned air, then turn the fan on and blow canned air in it again so all the "dust bunnies" get blown out from the center. Then use something like a small screwdriver to pull the big dust clusters that get stuck in the front grill.
Fan runs alot and the laptop over heats and shuts down
hello
keep your notebook well ventilated (there are vent grills at bottom that ned to be kept ditanced from the notebook to the flat hard surface where you place the notebook. Also, try to clean the fan , by removing bottom cover : use air can to blow away dust - clean the fan. If the system has never been cleaned before, i can assure you there is mounds of duct inside , especially on the fins of the heatsink fan that cools your CPU and video card. I would also suggest getting air compressor to blow away the dust , if there is too much of it inside. YOU MAY HAVE TO REPLACE THE FAN unit . You can otherwise , go to teh BIOS set up nad reduce the fan speed.
Feb 25, 2012 | Toshiba L505D-S5965 (PSLM0U-00F002) PC...
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fans on Mac Intel Tower
I would suspect it needs a good internal cleaning. The accumulated dust will cause the computer to overheat. Disconnect all cables and take the unit to a place where you can clean it. Remove the side panel and then with a can of compressed air or an air compressor blow all dust out of the unit. Pay special attention to the heat sink on the processor. Make sure you clean the power supply fan. Be sure and not touch any internal components without first grounding yourself to the chassis. It is best to do this outside as the dust will fly everywhere. You should clean the inside at least once a year. Merry Christmas.
Dec 15, 2009 | Intel Mac Pro Tower Desktop
Fan very loud all the time
probably easiest if you take the back cover off your laptop, and remove the fan completely. then remove your fan. clean all the dust from this, and also clean any air vents. obove the fan should be a metal grid thing. clean all the dust from this! this is the heatsink. usually you should use a can of compressed air. but i use a vaccum cleaner - USE VACUM CLEANER AT YOUR OWN RISK. IT CAN CAUSE STATIC ELECTRICITY DAMAGE.
Oct 14, 2009 | ASUS M51Sn-C1 Notebook
Why does our xbox 360 make so much noise when running
The possible and most likely culprit is that after a while the inside of your 360 collects alot of dust and that dust builds up inside and on your fan. So I suggest you goto any local Walmart, kMart, Computer Store and purchase a can of that compressed air and use that to blow the dust out. Do not use a regular compressor because condensation builds up inside the compressor and will blow alot of water into your system and if you blow water in your 360 and plug it in you are going to have bigger problems than a noisy fan. The best fix is to actually open the case and clean it out that way. But by doing this you Void your warranty with Microsoft. So that is on you.
Sep 28, 2009 | Microsoft Xbox 360 Arcade
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
My turbo chef owen sense somtime 208vac and some time 240vac
Hello. If you take the right side panel off, unplug first please. at the back is a blower motor, two screws on the back vertical rail, and one at the front edge of where it is connected to blow, probably under the foil tape, this will remove the blower. On the back wall toward the bottom, under all the relays, is a voltage transformer that tells the controller which voltage you have, replace it, and problem will be corrected. If you are not comfortable with this, call Turbo Chef for a local servicer, and call them to repair.
As for the F6 EC error, you are having a temperature problem due to the control area overheating, there is a blower on the back, and vents on the front, and side, either these are clogged, the fan grid is clogged, and the interior has alot of dust coating the interior of the right side, please unplug, vacuum, and clean out the dust etc.., after reassembly, after about 30 minutes of operation, the blower on the back should be on, if not you need another.
Hope that helps, and thank you.
Mar 21, 2009 | TurboChef TORNADO Electric Oven
Dust inside of the main screen of my Moto V3
please check local service center if they can assist you on this issue.
Aug 15, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Lasko 2554 WIND CURVE Fan Logo
628 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
