Question about Nintendo Wii Console
Just plugged in my wii and i am only getting a black and white picture
    Problem Solver:
  • 18 Answers
Your TV output is on the wrong setting for your tv. or your scart cable is not fully connected.
Posted on Sep 12, 2010
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Why is my Samsung tv only showing black and white picture?
If the normal TV channels are OK then the wrong input has been selected. Probably set to component instead of composite.
Oct 14, 2017 | Samsung SyncMaster Televison & Video
I have a Samsung tv that has no place to plug in the yellow cord. It is a new high dollar HDTV what do I need to get the wii to play? No, there is no yellow hole, the picture is black and white, with...
The only way I was able to get around this was to plug into use component 1 then plug the yellow into the green on the far right. The problem I now have is that I can only use component 1. When I plug a dvd or wii into component 2, it shows still shows up in black & white, even when I plug the yellow into the green. I am not a happy Samsung owner.
Dec 25, 2009 | EA Sports Tiger Woods PGA Tour 08 for...
Wii plays in black and white.
Check if the tv has different types of AV settings, as this affects whether the wii plays in black and white or colour.
Aug 04, 2009 | Nintendo Wii Console
Black and white picture
Yeh, Ok.
What you need is called a component cable if your TV has 6 ports.
If it has 3, the one your wii came with.
Hope this helped
Dec 24, 2008 | Nintendo Wii Console
Had the same problem, went to Currys and bought a switchable scart adapter, on the receipt it's called a BELKIN 3 RCASCART ADAPTER £14.67. Plugged it in, sorted. Hope this helps, happy playing.
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
Wii in Black & White
not to sure about the wii have you treid here for any tips
http://nintendo.com/consumer/systems/wii/en_na/system.jsp
riz.
Nov 01, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
