Question about Lenovo Thinkpad T60 Notebook
My T60 Lenovo turns to black screen after a couple of seconds. What will I do is standby the system to restore the screen but the error will occur again after a couple of seconds. This usually happen when my laptop was plugged to the power chord. When I am using my battery and its below 40% this error will also occur. Hope you can help me on this problem.
    Scholar:
  • 183 Answers
Boot up in safe mode (press F8 0on startup) on your normal login name. Once in safe mode disable the screensaver, then go to power options and disable them so that there are no powersaving features enabled.. Then restart into normal windows, and hopefully everything will be fine.
Posted on Aug 29, 2010
How do I fix my IBM T60 Lenovo laptop thinkpad it won't boot and and NTLDR IS MISSING
The hard disk is crashed or erased. Need to reinstall the operating system or restore from backup.
Dec 27, 2013 | IBM Lenovo ThinkPad T60
How can I fix my Lenovo laptop if the screen keeps turning black. The cursor will still move but I can't do anything else
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 14, 2013 | Lenovo G570 43349EU 15.6" Windows 7 Home...
Windows won't start
re-install the operating system or restore from a set of back up discs you previously made from the laptop.
Dec 23, 2012 | IBM Lenovo ThinkPad T60
Lenovo ThinkPad T60 goes to blank screen at random intervals.
Hello you just have to upgrade the driver for the graphic card.
You can also use windows update
Visit lenovo here:
Or use the autodetect function
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-62928
If it not helps with the driver your display has a defect
its not a easy task to change the display.
The local computer repair shop should be able to help you with that.
Good luck
Aug 14, 2012 | IBM ThinkPad T60 Notebook
My Lenovo T60's Screen turns black with the backlight still on, the computer is running but i cannot see anything. What do you suppose is wrong?
Welcome to Fixya
The backlight must have turned Off. Look at the F keys ( F1, F2 etc) that has picture of the LCD. Press Fn + the key that has the LCD picture to turn on the backlight. If nothing happens, try to use external monitor. If you see the display using the external monitor then the problem is the LCD already.
Thank you for using Fixya!
Sep 19, 2011 | Lenovo Thinkpad T60 Notebook
Screen goes black after 45 seconds
First you need to check in BIOS,
Turn on your computer, and then keep on tapping F2 key, get to BIOS, wait for 45sec then check?
If issue persits then contact manufactoror or loacl repair shop
IF issue dont persits then,
press F9, load default BIOS mode
press F10 save and exit setting,
If issue persists,
go to safemode by tapping F8 key as soon as you turn on your computer,
restore you computer to the date computer was working fine...
If not try for video driver reinstallation, you will driver from support.acer.com
Try this... hope it will work
Apr 26, 2010 | Lenovo Thinkpad T60 Notebook
My lenovo t60 screen goes black 15 seconds after
Hi, try to boot into safemode, turn your system on then keep on tapping F8 to get the windows advance Menu screen, select safemode.
In the safemode windows go to Control panel and check your power options, you will see what time frame your system has for the LCD when turning off.
If this does not fix the issue, try booting into safemode with networking for you to be able to go online in safemode try updating your BIOS from your Manufacturers Website, Updating your bios may fix the issue.
Mar 12, 2010 | Lenovo Thinkpad T60 Notebook
Error loading up system
If you can get into safe mode by pressing F8 when you first turn on the computer then you can possibly do a system restore on it back to the last date the computer was last working properly.
If you can't get into safe mode then you'll need to restore your computer back to factory defaults like you just got it out of the box.
Aug 22, 2009 | Computers & Internet
Back screen (no screen) upon powering my T60 thinkpad
  1. Take out your battery and the power button for about 60secs.
  2. Start the laptop using the Adapter [without the battery]
  3. Lighten up your laptop...remove any external device attached [printer,scanner,pen drives etc.].
  4. It could also be a RAM problem,try changing the RAM if you have two start with one and exchange them.Clean the edges of the RAM where it get fits into the slots and blow some air in the slots to clean it up of any dirt.
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE to restore it back to an earlier date when laptop was ok. THEN LATER ON PUT THE BATTERY BACK IN.
  • Try restarting after an hour gap.
  • If this doesn't solve your problem call the company people.Their might be a Video Card problem or any other internal hardware problem.
Aug 05, 2009 | Lenovo ThinkPad T61 Notebook
I have a error code 0x0 message after boot-up on my toshiba M50 series laptop. any help pls
Hi, try pressing the power button for a long time and then let it turn off for itself wait for some moments and then press it on again, if it doesn't work, try system restore or something
May 19, 2009 | Lenovo Thinkpad T60 Notebook
Lenovo Thinkpad T60 Notebook Logo
315 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
