Question about Microwave Ovens
Manual for T-Fal multi grill store away - Microwave Ovens
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
Hi i have a george forman grilling machine GR10ABWG model number 10198 ,and i am looking for operating instructions and recipes,can you help,thanks very much
HELLO.
solution below.
The best place to get the GRILLING MACHINE manual guide is to visit the manufacturer website to order for the manual stating the GRILLING MACHINE model number and give our house detailed address.
However GRILLING MACHINE manual guide can also be purchase at any GRILLING MACHINE authorized dealers around your local area with the model number for compactibility(easy use).
Thanks.
Sep 20, 2011 | Microwave Ovens
I am trying to locate the user manual for the T-Fal Sensor 3215 pressure cooker. As i saw in a web posting it is old and T-Fal no longer makes pressures cookers. That person contacted T-Fal and request...
Hello boptimystic,
I understand you need the number to contact T-Fal. Here is the number and hours of operation:
Call us at 800-395-8325 or send us a note.
Call center hours are Monday to Friday 8:30am to 5:30pm
Apr 25, 2011 | Microwave Ovens
Is there any chance the manual is still out there for the party grill 870 ?
Look on the bottom of the unit for the Product code number. Then use that number and check here:
http://www.sunbeam.com.au/Pages/Support/ManualSearch.aspx I tried 870 and it did not work. If I remember correctly this is a 1950's era grill. (just may not be a manual out there)
If you can not find it there use this contact link:
http://www.sunbeam.com.au/Pages/Support/ContactUs.aspx
and ask them for a manual for your Model 870 party grill.
A search of E-bay did not reveal a manual but it did show the Grill for $9.95.
http://www.hammerwall.com is usually the other source for kitchen appliance manuals and it was not listed there either.
Good luck and thanks for choosing FixYa,
Kelly
Apr 03, 2011 | Microwave Ovens
Looking for a link to a user manual for a T-FAL 1656 iron.
You can get the manual on the link below. Scroll down to product detail then click on product manual.
http://www.amazon.com/T-Fal-1656-Ultraglide-Iron/dp/B000050AUS
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Microwave Ovens
Where can I go to get a user manual for Carlton C17GSS09 microwave
Is thisa the 39 Pound special?
Try Curries in the UK they are cheap units made for sales as specials.
Beware tho if they break down tjhey are considered throw away.
Capacity - 17 litres, Microwave wattage - 700W, Grill wattage - 1000W, External dimensions WDH(mm) - 440x318x252, Stainless steel door with silver casing, Power levels - 5, Auto programmes - Defrost/cook, 8 auto cook programmes
The cheapest price Currys for CARLTON C17GSS09 is £39.00. For more information on CARLTON C17GSS09 please visit their online store.
CARLTON C17GSS09 is available from as little as £39.00.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Microwave Ovens
Jenn air microwave jmv8208bas The light bulb went out. How do I replace it?
From the service manual:
The top full-width grille is removable for service to some components, such as: humidity sensor, oven light, door removal, flame sensor, vent motor capacitor, fuse, control panel, and stirrer motor (some models).
Grille Removal
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
3. Pull outward on the top portion of the grille releasing the tabs.
4. Reassemble in reverse order.
The oven lamp part original number is 4713−001165 but you can get it locally (generics) at hardware stores, appliance parts stores, etc. It's a common 20 watt halogen bulb.
Oct 21, 2008 | Microwave Ovens
Microwave Ovens Logo
333 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
