Question about HP Pavilion dv6000z Notebook
Screen is black when I turn on notebook - HP Pavilion dv6000z Notebook
    Sergeant:
  • 223 Answers
Sounds like you may have the monitor set to an external monitor. look for a Fn key and press it in combination with the monitor key - typically located near the F8 key it should be an icon in blue that looks like a monitor. press this combination and see if it comes back up.
Posted on Aug 29, 2010
  • 2 more comments
  • Trevor Groves
    Trevor Groves Aug 29, 2010
    take a flashlight and look carefully at the screen, do you see stuff very faintly? it could be that your backlight inverter has gone belly up, and needs to be replaced.
    Secondly, turn the laptop on so you have some activity, then press and hold power button until it shuts off. This is a hard reset. if your computer is stuck in a sleep mode, this will fix it.
    Does that help at all?
  • Trevor Groves
    Trevor Groves Aug 30, 2010
    please add a comment, were you able to see anything on your screen with the flashlight very faintly?
  • Trevor Groves
    After reviewing this one more time and looking very carefully at your model I regrettably have to show you a thread from HP directly. Be sure to make up a big cup of coffee and get some aspirin.
    I have one of these on my tech bench. The hard drive was full of bad sectors, had to run Hirens boot cd and use HDD regen to recover, then copied my data to the a new hard drive, but i am still not confident this will solve the real problem at hand. Please have a read, you will find this enlightening, sorry to hear you may in this boat too. Click here for link
  • Trevor Groves
    Trevor Groves Sep 03, 2010
    I haven't seen any further comments from you on your problem. Did Any of my suggestions help?? leaving a "didn't help" thumbs rating indicates your still having the problem. Please add a comment or consider changing your rating.
Toshiba Satellite P505D-S8000 black screen
have you changed all cables, is there power gettint to unit? could be bad lcd or inverter
Feb 09, 2013 | Toshiba Satellite P505D-S8000 18.4"...
Screen all black.
Aside from the screen being all black, I am assuming that the notebook seems to be operating normally. So I suspect the screen's back light may have been turned off by Power Management. Usually pressing any key should turn the back light on but if this doesn't happen, try pressing the Fn key at the lower right of the keyboard and while holding it down press the F6 key at the top center of the keyboard. If this works, you should check the notebook's Power Management profile to see if it is the way you would want it to be. For example, normally if the notebook is on AC power, the screen should never turn off.
Mar 22, 2011 | Acer Aspire 5315 Notebook
I have an Acer aspire 5534 that is less then a year old. I noticed that the screen started to have red lines and the coloring was off today so I restarted it. It then had a white screen so I turned it off...
Hi
The problem with your PC Notebook has to do with the screen.Since you can hear the sound then your screen might be damaged maybe mistakenly.
You just have to get to the right store and replace the screen so your notebook can work perfectly.
GOODLUCK
Jun 16, 2010 | Acer Aspire 55345410 Notebook
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: the screen goes black after the hp logo comes on w...
its generally due to static stored in the notebook ....which stuck the turn on process of the notebook...
turn off the notebook ,, remove the battery .. press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on the notebook it will start ,,,
if it not check in the safe mode
May 18, 2010 | HP Pavilion dv9000z Notebook
Hp dv5000 Screen blacks out
sounds like the backlight is going out do me a favor turn it on and put a light source next to the screen if you can see everything on your screen then its the backlight
Mar 10, 2009 | HP Pavillion ZV6000 Notebook
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
Screen blinking:
first check out if the screen saver is enabled to make your screen black. but if you are using your computer and the screen blinks or turns black there is a loose contact of wire in your computer. bring it to the service center of your notebook and have it fix.
Dec 22, 2008 | Acer Aspire 4520-5582 Notebook
ECS Elitegroup lcd screen turns black after the unit is switched on after a time
It would be either the backlight behind the LCD or the inverter board capacitors going out, my suggestion buy a new LCD screen.
Mar 08, 2008 | EliteGroup ECS A535 Notebook
Gateway notebook problem
Black Screen of Death - BSoD Black Screen of Death or BSoD computer dictionary definition and information.
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Gateway 450ROG Notebook
HP Pavilion dv6000z Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
