Question about Kenmore 17459 Free-standing Dishwasher
Replace broken caster wheels on portable Kenmore dishwasher?
4 Suggested Answers
SOURCE: GE dishwasher nautilus - bottom tray caster wheels come off daily.
I finally found a solution after 2 years! Appliancezone.com has wheels and studs to fix problem. WD12x10136 and wd12x10277. About $17.00 and rack is rolling perfectly. GE wanted 200 for an entire rack, no thank you!
Posted on Aug 05, 2010
  • 4 Answers
SOURCE: broken casters (wheels)
FAST and EASY SOLUTION that WORKS!
DO NOT TAKE THE DISHWASHER APART!!!!!
but Turn it UPSIDE DOWN
There should be a Drain Plug (if you got water there)
If a wheel breaks
1) use pliers to pull whats left of the plastic wheel off the metal fixed shaft
2) buy replacement wheel from Home Depot
Shepherd 2 in. Twin-Wheel Stem Casters 2 Pack
http://www.homedepot.com/h_d1/N-5yc1v/R-100082918/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
3) use pliers one again to pull the shaft of out the Home Depot plastic wheel (takes some works)
4) attached the new plastic wheel to the Dishwasher's metal wheel shaft (if the wheel is loose, add some tape to the metal shaft to make it tighter fix)
5) your done, simple as ABC123
6) clean your dishes and smile :-)
Posted on May 10, 2011
SOURCE: kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Posted on Feb 08, 2012
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
Caster broken
Some caster wheels are a press fit on an axle. That's why they frequently fall off.
Feb 19, 2014 | Goldstar DH304 Dehumidifier
Need replace a wheel
Home Depot sells casters (wheels),, pull one off and take it with you .
that way you'll find a match... the caster will problably have a post going into the leg. just pull it down to remove.. Good luck.. Geoff
Mar 09, 2012 | Delta Portable Baby Bassinet
I need to replace the tires and casters on my probasics wheelchair. I am not sure what I should order and whether the tires come on the wheels ot what.
As a general rule, it is best to replace the caster as a complete assembly consisting of tire and wheel hub. Usually this is the only way to replace casters when the tire is molded on to the wheel hub. It is the best way to replace the caster since you get a tire, wheel hub and 2 new bearings.
With regard to the drive wheels on a manual wheelchair you can get just a new tire. With a plastic mag wheel and hand-rim you can sometimes get just a replacement snap-on tire to replace the existing.(Snaps on like a rubber band using tire irons). If the hand-rim, wheel, spokes, and bearings are worn or broken, you are usually better off replacing the wheel assembly. With power chairs, it is more cost effective to only replace the drive tires and use the existing wheel rims. Hope this helps.
Dec 23, 2010 | Probasics Health & Beauty
Need 2 casters
Is the model number FMP330RGB as listed at the very top? That number does not cross.
There are the parts listed as wheels / caster for Frigidaire:
http://www.repairclinic.com/Frigidaire-Dishwasher-Parts?s=b2a9c252
If you need more assistance just respond here with the complete make and model number and we will help you.
Thanks for using FixYa.
Kelly
May 12, 2010 | Frigidaire FMP330RGB Free-Standing...
Broken wheel roller on a PAC-121 portable air conditioner
Yes, you can. The caster part number is 2040-0142 and can be found at some online retailers.
PartsGuy.com
Appliancefactoryparts.com
Feb 18, 2009 | Comfort-Aire PAC-121 Air Conditioner
My portable danby is stuck on the Drain cycle
take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Sep 25, 2008 | Danby DDW1805W Designer Series...
Caster wheel broken
whats the model number
May 05, 2008 | Dishwashers
Broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
Aug 28, 2006 | Danby DDW1805W Designer Series...
Kenmore 17459 Free-standing Dishwasher Logo
910 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
