Shift 3 mp3 can't find directory?
I try to put some songs on said mp3 player, but it won't let me;
says something about how it can't find the directory.
how do i fix this problem of mine?
  • readerfreek May 08, 2008
    my computer recognizes that there is a drive there but when i click on the properties it says that there is no space there.
Http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=200216654718#ebayphotohosting
this is what i got. when i plug it in it gives the screen of connecting. it also shows up on my computer but says that there are 0 bites free of 0 bites. any suggestions?
Posted on May 09, 2008
  • readerfreek May 09, 2008
    when i go to the properties is says a hitachi
  • 77 Answers
Hi!
What MP3 player are we talking about here? Maybe I could help you.
Posted on May 08, 2008
How do you put the 35 free songs on to the mp3
1.)Hook up the USB device to it, then to the computer
2.)Open up your computer directory and open the drive in which the device is coming from (the newest added drive that apears after you connect the mp3 player).
3.)Select your compatible file type songs (I think it's .wma files), copy and paste them to the root directory of the flash storage drive.
4.)Once the transfer is complete, unplug and try out the mp3 player.
Hope this helps!
Remember to Thumb me Up! :D
May 29, 2011 | Eclipse CLD2 MP3 Player
Mp3 files don't appear in music player, i inserted a memory card with some mp3 files and they won't appear in the music player, i tried putting them in different directories on the card and still no luck....
-try to move all songs outside the directory using your pc then test.
if still not working,
-insert your sd card to your phone and reformat it not on pc,then remove it and start again uploading mp3 songs then test.
Dec 27, 2009 | LG Vu CU920 Cellular Phone
Nextar MA933A-20P will only play factory installed files.Music files add are present but will not play. Will only shuttle between classical and fast dance files
The following may help:
1) Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format)
2) Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. 3) If you have uploaded your songs with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player) ps. To reformat your Music files to the player acceptabel format, you need to download and use a 'Audio Media Converter'.
Dec 20, 2009 | Nextar MA933A MP3 Player
I downloaded music onto my element gc-820 then go to listen and it says no file what the hell
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Dec 19, 2009 | Sears GC-820 MP3 Player
It wont play the downloading songs
Dec 19, 2009 | Element Electronics Zr-Element Digital...
I added songs which I can see via computer but not on the device itself
Verify that the songs are going into the correct directory on the device. If you are using software that came with your Sansa, it should be putting those songs into the proper directory automatically. Otherwise, I'd consult my manual and reset the unit to factory settings and add the songs again from scratch.
Aug 06, 2009 | SanDisk Sansa e250 MP3 Player
Removing songs
You can remove the song through buy sansa c200 software or you can remove directly by connecting through system.
Feb 23, 2008 | SanDisk Sansa c200 MP3 Player
My mp3 player won't let me put any song onto it
format the plaer again and use it..
format it from your system.. do a normal format.. not a quick format..
Jan 19, 2008 | Innovage Personal CD Player
Shift mp3 player
i cant find any web sites with free songs and im trying to put songs on my mp3
Jan 03, 2008 | Audio Players & Recorders
37 people viewed this question
 Grubhead
Grubhead
