Question about Toro Lawn Mower With Toro Power Tools
What kind of fuel does the Toro power plus 400 walk behind mower use
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
  • 246 Answers
SOURCE: no drive
Hello orlywooldrid:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers (20622) and Click Search. Now Select View Assembly Drawings for your Year Model.
Everything you Asked is at the Above Site Addy.
Parts can Also be Purchased from this Site Addy;
http://www.outdoordistributors.com/
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 39 Answers
SOURCE: toro walk behind mower battery will not stay
If the battery won't stay charged it most likely needs to be replaced. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html . They should have the battery you are looking for.
Posted on Jun 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: blade not engaging
The blade will spin automatically when the motor runs because it is connected to the main shaft. If it is not cutting, it will have to be removed and sharpened with a grinding wheel
Posted on Jul 03, 2009
SOURCE: 6.5 toro walk behind self propell b&s engine.
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Posted on Aug 07, 2009
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
Lost instuction manual for Toro lawn mower 20333 (Walk at your own pace) . What kind of gas or oil do I use? How much of each or do I just use one of them?
I advise you to call your service provider about the lost of your manual. They can definitely help you get a copy of it. The manual for your Toro Lawn Mower is the best answer for your questions. Thanks.
Jul 10, 2011 | Toro Personal Pace CARB Walk Power Mower
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Fuel flow problem
Maybe the main jet has something in it. I once found a fir needle in one. Don't ask me how it got there.
Jun 13, 2010 | Toro Walk Behind 30678 Commercial Walk...
Toro walk behind mower battery will not stay charged overnight,can't find a short
Apr 11, 2009 | Toro Lawn Mower With Toro Power Tools
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
268 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
