Question about Dell Inspiron 1525 Notebook
When i turn on my laptop it is telling me that there is no internal hard disk drive not found. To resolve this issue try to reseat the drive. Then it tells me there are no bootable devices--strike F1 to retry boot, F2 for setup utility, Press F5 to run onboard diagnostics. How do I reseat the hard drive?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 141 Answers
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Posted on Aug 29, 2010
HEPL !!!!
More than likely your hard drive just died. Bring it in to a pc fixit shop.
Jul 24, 2012 | Dell Computers & Internet
Can you tell me step by step directions on how to reseat my hard drive on a dell inspiron 1545?
Turn off power, remove battery.
Flip it over and look to the bottom right. Remove the 4 screws with a small Phillips screw driver.
Pull out hard drive slot. Remove the screws attaching the slot, fix new hard drive in old hard drive's place.
Put screws back in, plug back in battery.
It really doesn't get any easier than this, kudos to Dell for making it easily serviceable.
if you are still unsure watch the youtube
http://www.youtube.com/watch?v=ZILBkW7Zmfo
hope this helps
Jul 24, 2012 | Dell 160 GB 7200 RPM SATA Internal for...
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
Sep 12, 2011 | Dell Inspiron 1525 Notebook
DELL INSPIRON 1545 (Windows 7) My laptop is displaying the message below when switched on: Internal hard disk drive not found. To resolve this issue, try to reseat the drive No bootable devices...
Hi
It seems that the Hard Disk is disconnected from it's connectors
It needs to be fixed and installed correctly.
To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly.
If it's difficult to you, go to technician to do that.
Please, Tell us your results.
Good Luck
May 20, 2011 | Dell Inspiron 1545 Notebook
I have a two-year old Dell Inspiron 1525 laptop. for no apparent reason, it will now not boot up. When I turn it on, I get the following message......"Internal hard disk not found. To resolve this...
The hard drive may have failed or a virus has corrupted the Cmos data.
Try entering the BIOS and checking that the Cmos recognises that the hard drive is there. If it doesn't, remove the hard drive and re fit it, booting up again.
Dec 27, 2010 | Dell Inspiron 1525 Notebook
Says internal hard disk drive not found, to resolve this issue, try to reseat the drive
The hard disk has died, you will have to replace it with a new one then reinstall Windows using the recovery disk.
Dec 10, 2010 | Dell Inspiron 1525 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
How to reseat the hard disk drive
If the HD has never been removed it is unlikely it needs reseated. You need to go into the BIOS (press F1 during start-up) and see if the HD is visable under the drives section. If it is not then it is dead and needs replaced. Data recovery may be necessary if you need anything from it.
However to reseat it, turn the laptop over and there are two screws that come out to slide the HD out from the side. Pull it out and then push it back in firmly and replace the screws.
http://support.dell.com/support/edocs/systems/latd630/en/SM_EN/index.htm
Jun 07, 2009 | Acer Aspire 4315 Notebook
Dell Inspiron 1525 Notebook Logo
682 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
