Question about GE JDP39 Electric Kitchen Range
I have a GE range model #JDP3980W188. The "Start" button that turns on the oven no longer works. Is this repairable?
SOURCE: Ge Profile XL44 - Everything works except the Oven, it just stopped
lockrd door flashes on and off cant use oven
Posted on Dec 26, 2007
I figured out what the Issue is with my oven. I took off the back panel, a wire which runs from the teperature control knob to what I think mught be the thermostat is burnt off. I cleaned the wire and temporarily twisted it back on and the oven works now. I will call a tech tomorrow to replace the wire and put the tester on it to make sure the thermostat works properly so the wire wont burn off again or catch the oven on fire.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
SOURCE: LG Electric Range Oven touchpad buttons not working
Our LG range suffered from the "4" and "5" buttons not working, the large-to-small element selector not working plus several up and down functions not enabled. Technician unplugged the range, removed the back, unplugged and repluggged all the ribbon connectors. All works now.
Posted on Dec 22, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
My Ge Stove Xl44 model JGBP79 the oven will not turn off, all other button seem to work but this one
It is possible the touch pad is not working. If you unplug the stove and the oven shuts off then it is more that likely the touch pad.
Sep 25, 2014 | Kitchen Ranges
I need a thorough description of this kitchen range GEC2S980S; number of burners, size, available colors, price, etc.
Visit the ge appliance web site and Key in your model number C2S980SEMSS and you will get a complete breakdown of all specs and features as well as the ability to look at specific dimensions and product installation the guide.
Try this link:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=C2S980SEMSS
Aug 18, 2010 | GE Cafe C2S980S Kitchen Range
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
The f7 number keeps beeping on my GE profile range. i am assuming the oven is no longer working as nothing happens when i push the bake button. the most annoying problem is that f7 beeps all the time; it...
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
you have a stuck button on the key pad you will need a new control board to fix this.
goto http://lartoday.com/order_parts.htm , enter your full model number and search for control
levi
Lebarchrigen Appliance Repair
Mt. Holly, NJ 08060
www.lartoday.com
Dec 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE oven that is getting an intermittent F3 or sometimes F2 error. I am an electronics technician. I just need to know what to look for to fix this problem. Thanks Model# JDP3980W188
F2 indicates that the oven detected an over temperature condition. This could be caused by several things including a bad temperature sensor or problem in the door lock circuit.
F3 indicates an open temperature sensor ... so likely the cause of both. It should read 1180 ohms at 70F unplugged from the controller.
I can send you the tech sheet if you email me at bruce@fixyourboard.com (include the details in your email).
Oct 09, 2009 | GE JDP39 Electric Kitchen Range
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Malfunctioning Display and Start Button for Oven
The problem is with your Electronic Oven Control (EOC) board and/or keyboard overlay. All the oven features are controlled by the EOC. That's why you're experiencing problems with the oven operations, while the surface burners should be working fine. The cost of a new EOC varies between models. I tried to do a parts search, but could not find any information with the model number you provided. Double check your model number again. It should be located on a nameplate somewhere around the oven door or lower drawer opening. On some models, this information will be located on the back of the range.
To locate parts information, you can go to either searspartsdirect.com or repairclinic.com. Just type in your COMPLETE model number in the Search menu. The part may be listed as an "Electronic Oven Control", "Oven Control", "Main Control", or "Timer Control". Both sites offer competitive pricing, but the Sears site has helpful illustrations that make part identification and assembly much easier.
Do you have a current warranty? Unless you purchased an extended warranty or service plan with your range, most manufacturers only provide a one-year limited warranty. In some cases, however, the manufacturer may have extended coverage on certain items. It may be worth while to refer to your owner's manual to see if there is any warranty information available.
If you go to geappliances.com there is some helpful information under the "Service & Support" heading in the drop down listing under the "Search" window. In addition, there are toll free numbers provided to assist you with any questions you may have.
I hope you find this information helpful to you. Replacing the part yourself will reduce the cost of the repair greatly (if not covered under warranty). Let me know if you decide to repair this yourself and need further instructions.
May 22, 2008 | GE JBP72SKSS Stainless Steel Electric...
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE JDP39 Electric Kitchen Range Logo
119 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
