Question about Whirlpool GGW9200L Gas Dryer
Dryer turns off and shoes e1 code
Every time i turn on the dryer it runs for a couple min then stops and flashes an e1 code. i tried unplugging the machine and cleaning out all the lint everywhere and it hasnt work. what is that code for
  • Anonymous Oct 15, 2008
    My dryer does the same thing. Sometimes it will work when it hasn't been used overnight.
E1- Thermistor open.
It monitors the exhaust temperature, and cycles the heater relay on and off to maintain the desired temperature.
It could be the sensor, or electronics.
Posted on Aug 29, 2008
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
Frigidaire Gallery model GLEQ2170KSO dryer turns off within a minute.
Hello allisonarena - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn on the unit. If issue persists, then the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I would recommend connecting with an experienced appliance repair tech to assist further and to reduce the risk of unnecessary parts.
Jun 12, 2013 | Frigidaire Dryers
Samsung DV409sel Fairly newv (less than a year) Settings are seleted, start is pressed, a click is heard inside but the machine doesn't start. Flashing clothe icon on display. Tried different...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Dryers
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
Code E1
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do I gain access to the gas valve coils on my Kenmore 80 series gas dryer?
I have a E1 code on my Kenmore H3 dryer. it runs great and then 15 mins into it E1 appears and it stops. Help!
Jun 03, 2009 | Kenmore 659 Electric Dryer
I'm getting an E1 signal from dryer...What is the
This usually works to unlock the E1 code
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal buttonfor 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
If this worked for you don't forget to give me a ranking. Thank you!
May 06, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer turns off after 30 seconds and beeps six times (over and over.....)
other than a good lint cleaning by dissasemble and if not then replace the motor
Jun 23, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GGW9200L Gas Dryer Logo
169 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
