Question about Frigidaire FEB30S5D Electric Single Oven
Frigidaire stove with oven
My oven doesn't even preheat to 350. I would preheat it to 350, but an hour later, it would only be warm. Why?
    Sergeant:
    Champion:
  • 260 Answers
I had a similar issue. Did you change the element in the bottom? Make sure you have a good seal on stove.
Posted on Apr 09, 2009
I have the same problem. Any resolutions for you?
Posted on Sep 01, 2008
I purchased and installed a new baking element in my Frigidaire oven and set the oven to preheat to 350. The oven will warm but will not reach temperature setting
Check the element connections first. 99% I would say you have a poor or dirty connection causing poor current flow to the element. Then check the temp sensor.
Best wishes!
Nov 06, 2013 | Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
Nov 22, 2009 | Ovens
JRP 15 oven showed 350F and gave preheat beeps. Frozen lasagna "cooked" 45 mins and was still almost frozen. Oven was warm inside, not hot. Bottom element glowed orange when I increased the temp setting...
The oven was obviously not heated to 350 even though this was the setting. There is a very simple proceedure to calibrate the oven. It is different on different makes of ovens. Your owners manual will give you the detail of how to reset yours. If the manual is not available, click on the following link. Hope this is helpful.
http://www.applianceaid.com/temp-change.html
Oct 05, 2009 | GE JRP15 Electric Single Oven
I have a whirlpool range that was purchased 04 2000. last week when i would set it to preheat 350 i was smelling gas and the oven was not preheating unless i set it to 500 and then it wasnt getting as hot...
Hello , sounds like the electronic ignitor has went out , they are not difficult to replace if your willing , the part is around fifty dollars and it should only take about a half hour to replace. please let me know if you have any other questions.
Phil
Jan 08, 2009 | Ovens
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
Maytag MER5775QAS
Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
May 01, 2008 | Ovens
Oven won't turn off!
it probably needed to reset computer/electroics
but i would call customer service for the brand it is a dangerous thing to play with.
make sure there were no recalls also.
Apr 05, 2017 | Maytag CWE5800A Electric Double Oven
Frigidaire FEB30S5D Electric Single Oven Logo
230 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
