Question about Maytag Neptune MAH5500B Front Load Washer
My washer reads lr which i know what it means. is it something that i can fix myself?
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question %YH
Posted on Oct 01, 2010
Maytag neptune washing machine. The error code is Lr. I know what that means, but it is 11 years old and am wondering if it is worth it to fix or just replace.
I would say yes, just remember that replacement washing machines are getting really expensive. First, get a couple of quotes on repairing your Maytag washing machine. Ok, what does Lr. mean?
Maybe I could save you some money, that is if you are mechanical inclinded. GB...stewbison.
Sep 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Nov 27, 2010 | Maytag Neptune Washer
Code reads Lr- my washer is about 9-10 yrs old. Is this something that can be fixed or do I need to look for a new washer?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question *&^
Sep 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Dec 21, 2008 | Maytag Neptune Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
