Question about Water Heaters
Water very hot so changed the temperature on thermostat but now not operating at all - is it something to do with manual re-set?
  • 43,501 Answers
Yes, the rest probably tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
Posted on Aug 29, 2010
In temperature screen at 49 degrees to back to front t's appear and boiler stops
PDF]Operation and Installation Manual Outdoor Tankless Water ...
https://www.rinnai.us/.../U287-1932(00)_Outdoor_...
Rinnai America Corp.Temperature controlled continuous flow gas hot water system. .... This water heaterwill attempt to provide hot water at the temperature setting even when the ...
Hot water system temperatures and the code ' Plumbing ...
plumbingengineer.com/content/hot-water-system-temperatures-and-code
Feb 1, 2015 - There have also been incidents where the circulating pump stopped ...before it connects back to the cold water inlet to the water heater. .... Is there a maximum temperature limit for domestic water heaters? ... a means to limit the maximum setting at the valve to 120°F (49°C) or ... Some do and some don't.
[PDF]User's Operation Manual - contents - Navien
Dec 25, 2015 | Water Heaters
Tip
How to Change the Gas Valve and Thermostat on a Hot Water Heater
<p>If you are having<b> trouble with the temperatures</b> of your <b>gas hot water heater</b> fluctuating too much, or after <b>changing the thermocouple</b> of your gas <b>hot water heater</b> then you may need to change the complete <b>gas valve and thermostat assembly</b>. Also if you have changed the <b>thermocouple</b> and the pilot still will not stay lit, then the gas valve could be bad or the <b>ECO (Emergency Cutout)</b> may have activated and is open. This is a onetime device and cannot be replaced.<br /> <p><br /> <p>These instructions are for the older style <b>gas valve and thermostat combination</b>. These commonly have a large red knob that adjusts the temperature of the water. Also note that the burner tube nut for <b>natural gas</b> is right hand thread, but if you have <b>LP or propane gas</b> the burner tube nut is left hand thread.<br /> <p><br /> <p>The newer <b>gas valve thermostat combinations</b> that have come out recently are similar, but they have a well in the tank that the sensor slides into. The assembly is held fast with a set screw. With this type of <b>gas valve and thermostat unit </b>the tank does not need to be drained, but most of the rest of the change out is similar.<br /><br />To change a <b>gas hot water heater thermostat</b> you will need to first buy a new gas valve for your <b>hot water heater</b>. The <b>gas valve</b> and the <b>thermostat</b> are integrated into one unit.<br /><br />To <b>replace the thermostat on a gas hot water heater</b> you must follow these procedures....<br /><br />1. Turn off the incoming water and<b> drain the hot water heater</b>.<br /><br />2. Remove the <b>pilot tube</b>, the <b>burner gas tube</b> and the thermocouple from the gas valve. Turn off the <b>gas line</b> and remove from the gas valve.<br /><br />3. Get a <b>pump pliers</b> or a<b> wrench</b> in behind the gas valve and turn the whole assembly CCW to remove it from the tank.<br /><br />4. After applying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the <b>ECO</b>. They are the little red wires on the back. If you break them the assembly is irreparably damaged.<br /><br />5. Reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.<br /><br />6. Fill tank with water. Make sure to open a <b>hot water faucet</b> and <b>purge all air from the tank.<br /><br /></b>7. <b>Check for leaks</b> where the gas line hooks up with soapy water.<br /><br />8. Relight pilot light and check operation.<br /><br />9. Set the new temperature setting to a medium setting and then adjust the temperature to your liking from there and adequate time for heating completely<br /> <p>
on Feb 25, 2011 | Water Heaters
Tip
Electric Hot Water Heater Temperature Adjustment
If your electric hot water heater is not getting your water hot enough or your water is too hot then you can make the adjustment easily yourself. There are a few things that you may need to know to do this. I will go over where the thermostat(s) are located and also how to make the changes.
The first thing to remember is to make sure that the power is turned off to the hot water heater before you attempt to open any of the covers and make any adjustments.
The next thing is to locate the covers which are over the thermostats and the elements. There are two on most hot water heaters, one for the top and one for the bottom. One or two screws hold these covers in place. They will look like this when you look at the front of the hot water heater.
When you have the cover removed you will see that the top thermostat, reset safety control and the element look like this.
The bottom thermostat and element look like this.
If you need to reset the hot water heater you push the red button on the top thermostat in hard till it clicks. To change the temperature setting on the thermostat you need to take a screw driver and turn the dial to the desired temperature either higher or lower as you prefer.
The elements can also be checked by using and ohm meter and checking for resistance across the two terminals of the element. If you get no resistance or a high resistance the element is no good. A normal reading with most meters will be somewhere in the 8-25 ohm range. This even gives a bit of buffer for different meters and the possibility of them being a bit out of calibration.
For most people a simple adjustment of the temperature settings will be sufficient to give you the results you want. Remember that you may need to adjust the thermostat for both elements to get the desired result. Also remember that you can get a longer time before you run out of hot water if the water is hoter and you mix more cold into it. The downside of that is the chances for scalding are greatly increased with hotter water. If you have small children or elderly adults, think carefully about what very hot water can do to them.
For higher efficiency you also want to keep the water temperatures as low as possible to reduce the residual heat loss of the stored hot water.
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
http://www.fixya.com/support/r4422595-electric_water_heater_wiring_diagram
http://www.fixya.com/support/r4041115-clean_hot_water_heater
http://www.fixya.com/support/r4656414-replace_thermostat_element_electric_hot
on Apr 29, 2010 | Water Heaters
No hot water comes into the house
1) Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#no
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
2) One pipe on top of heater is warm??? >> breaker is ON >>> this indicates that electric water heater has hot water.
When you opened the TP valve, did hot water come out???
3) Feb 2013 >> add a comment.
Feb 24, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
My rheem was flashing IL . I flushed with 2 gallons of vinegar for 45 minutes. however when I restarted it still is flashing IL. Does something in the remote need to be reset?
Before calling service technician, open following link for Rheem tankless troubleshoot resources, including on-line chat
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Rheem technical service bulletin for de-liming:
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
De-liming Manual says:
10. Turn on the water shutoff valves, run a hot water tap to
purge any air from the water lines and check the system
for any leaks.
11. Turn on gas, electricity, and remote control thermostat
and set the desired temperature.
12. Run hot water from several locations to check the operation
and performance of the water heater.
If you have difficulties please contact the Technical Service
Department at 1-800-432-8373 or your local service agent.
Apr 18, 2011 | Rheem Tankless Water Heater Main Remote...
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
What is the energy factor for the mod.82V80-2? I have two seperate 30amp circuits, one for the top element and one for the bottom element, if that changes anything.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
http://globalimageserver.com/fetchDocument.aspx?id=052c9e32-ce37-48d7-8990-9e430f23fef3
82V80-2 Energy factor is .86 according to water heater industry self-regulated standards.
Rheem pdf says these water heaters are wired for non-simultaneous operation.
Except special order water heaters.
Non-simultaneous operation uses single 240V circuit as described below.
If your water heater is wired for simultaneous operation, and each element is on a separate circuit, that makes your water heater special order. I would guess the reason is for higher first-hour delivery, which implies rapid heating and would likely affect energy factor.
You might want to get serial number off model and call Rheem for specs on that special order.
Your water heater energy factor may be the same because 'energy efficiency is based on the amount of hot water produced per unit of fuel consumed over a typical day.' This means an aircraft carrier can be considered highly efficient despite overall cost. And naturally the guys making the aircraft carrier are also doing the rating.
http://www.energysavers.gov/your_home/water_heating/index.cfm/mytopic=13000
Non simultaneous operation means the upper thermostat controls heating functions.
240V goes to upper thermostat first.
When water inside tank is cold, thermostat reads temperature through tank wall.
Upper thermostat turns on upper element until top 2/3 of tank reaches thermostat set point.
Once set point is reached, upper thermostat turns off upper element and sends power to lower thermostat and lower element.
Lower thermostat reads temperature through tank wall, and turns on lower element until bottom 1/3 of tank reaches thermostat set point.
As water cools inside tank, lower thermostat is first to respond since hot water rises.
Lower thermostat turns on lower element until tank again reaches set point.
When hot water faucet is turned on, hot water exits top of tank.
At same time, cold water enters bottom of tank through the dip tube.
The heating cycle repeats.
At all times, the electricity flows through upper thermostat. And upper thermostat is powered by one 240V circuit.
With simultaneous operation, the upper and lower thermostats work in same manner.
Except thermostats are wired separately.
Lower thermostat does not wait for upper part of tank to be heated first.
Lower thermostat turns on whenever lower part of tank cools.
The advantage is more hot water available rapidly when demand is high. This is called first hour recovery.
One method for reducing electric consumption is to set lower thermostat so it only turns on during certain times of day. For example Whirlpool Energy Smart operates in this manner and shaves a few bucks off the bill each month. This says that simultaneous operation is not an energy saver, unless that circuit controlling lower thermostat is set on a timer.
Dec 06, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
Apr 27, 2009 | General Electric Water Heaters
Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Dec 02, 2008 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
