Question about Home
No water to hand held. Danze Taju hand held shower, model D49115. When rubber trigger is pressed no water or pressure seems to be diverted to the hand held . Product has had limited use. Is there an easy fix? Or did I purchase a lemon?
  • bamullen Aug 29, 2010
    Thanks, however no water goes to the head. Would running hot water over the sprayer help(from the tap)?
  • 4,102 Answers
Hi it sounds to me like it has a stuck valve the problem with this is that they are sealed and you cant get to the valve to unstick it, have you tried running just hot water through it and see if that makes and difference if not i would take it back and get a replacement, if you have not had it that long just take it back without the receipt and tell them it dont work they will then replace it for you just say you only bought it a couple of weeks ago.
they have to replace it as a faulty part they wont give you your money back but they will replace it for you.
let me know how you get on or if you need further assistance ok
Posted on Aug 29, 2010
  • paul proctor Aug 29, 2010
    hi, if it will reach the tap give it a try the hotter the better it may just free the seal up and get it working if it dont then i would get a replacement, also have you tried unscrewing it from the shower and checking that their is nothing blocking the end such as a bit of plastic.
    have a look failing that i would take it back as you should have no problems with it, if you have not had it that long then it shouldnt pack up for at least 12 to 18 months
    let me know what you find ok
How danze shower lever which changes the water flow from the permanent shower head to the removeable freehand shower has fallen out. How can it be repaired?
Don't try to repair it. Replace it. All hand held showers use 1/2" hose fittings so any brand divertor should fit. Bring the part with you as there are different styles.
May 07, 2014 | Danze Home
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
Hi, We have a old 5-port diverter valve (Grohe 29 605) in our shower in which the outlets are connected thus: Hand held shower port connected to hand held shower Fixed head shower port connected to body...
yep replace the unit the plumbing will be ok for a new unit, with a setup lie that whoever installed it hopefully was smart to put shut off valves behind the wall or you will have to turn off h20o supply and replace and solder caps on the rest easier to change out to new
Mar 04, 2017 | Plumbing
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Home Logo
71 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
