Question about Elite Sl 3000 Ul Sliding Gate Operator
IM TRYING TO LOCATE THE LEARN BUTTON ON AA SL-3000-UL GATE SYTEM TO PROGRAME A REMOTE CONTROL
4 Suggested Answers
  • 116 Answers
SOURCE: Sliding gate will not close
Check track for obsticles, Does it slide smoothly or does it hand have way and get more difficult, Clean any sensors you can see with a clean rag. Let me know what you find.
Posted on Dec 11, 2008
  • 366 Answers
SOURCE: my sl 3000 ul gate wont open unless I help it out
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Posted on Jan 24, 2010
  • 19 Answers
SOURCE: Holiday Programming
the elite does not have that function, your are going to need to look for a time clock that holds open your gate...... the outside phone system or a programmable time clock that has been added to your gate...... oh this is an old post sorry. :)
Posted on Aug 16, 2010
MY ELITE SL 3000 UL WILL NOT WORK WITH REMOTE. IT WILL WORK WITH THE LOOP. PROBLEM WITH BATTERY OR NEED TO REPROGRAM THE REMOTE, IF SO WHERE IS THE LEARN XMITTER LOCATED PLEASE HELP
Hi Mary, do you have more than one remote for the gate? Your remote needs to be paired with the gate receiver. Normally you need to push a certain button on the control panel to enable learning mode then you press the remote button you want to use. You will have to follow this learning process for your device. Please keep in mind that just any remote will not work with your gate, it needs to be on the same frequency and use the same modulation mode.
Hope this helps.
Oct 28, 2014 | Elite Sl3000 1hp Slide Gate Motor,...
Trying to identify the "learn" button on my gate opener! Want to install the button for the gate on my Nissan Maxima 2013. Able to install the other two buttons for the two door garage openers but not for...
The elite comes with a liftmaster receiver located above the control box the older kinds were metallic under thelat cover there is a small learn button.
Oct 15, 2013 | Building Materials
My newly purchased home has a Beninca MS4 automatic gate opener but came with only one remote control (Liftmaster 371LM remote). I purchased two additional 371LM remotes online but do not know how to...
hi,
You have to oppen the motor control pannel. There will be circuit board inside it. In the circuit board you can see a Push button switch. It is the learn switch.
After powering ON press and release immediatly this learn switch. With in 30 seconds press and hold the button you wish to use until two click heard from the control board.
If you can sent me your email id through FixYa then i will sent the picture which shows the learn switch.
OK.
Aug 29, 2011 | Elite Sl 3000 Ul Sliding Gate Operator
My elite gate won't close. the charge ok led light is not on. checked everything and it's ok. switch limit switch on both sides works fine except when trying to close, it won't run.
If you disengage the motor does the gate slide easily? if not that could be the problem, most gate control boards have a sensor that detects the current drawn by the motor, if the gate hits an obstruction or is jammed the motor draws more current and the sensor stops the gate moving. It could also be a problem with the safety sensor, to check this locate the safety sensor input on the control panel and bridge the 2 contacts if the gate then works the safety sensor is the problem.
Dec 28, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
My sl 3000 ul gate wont open unless I help it out after i press button on board I have to turn motor shaft and push on gate and then it will catch and opne/close. Is it my motor or my worm gear?
Jan 24, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
How to program remote for elite sl-3000
http://www.liftmaster.com/consumerweb/pdfdocs/0150388.pdf
Nov 28, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Sl 3000 Ul Sliding Gate Operator Logo
287 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
