Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Kf42we610 Just replaced bulb after 3 years and after 5 hours the new bulb blew,any help would be appreciated
  • 425hunt May 08, 2008
    The lamp was just puchased and installed and within 5 hours the lamp blew ,,the fan is operating,what could have causesd this??
    Can something other cause a lamp to pop, the tv is in great condition ,,my question is before lamp gets replaced again can their be a short? also this was a replacement lamp not an actual Sony lamp,,would it matter??????
  • 563 Answers
Hi 425hunt
When did you purchase the lamp and how long has it been since it was replaced ?
A lamp normally comes with a warranty of it's own.
I've had a couple cases like yours before.
Posted on May 08, 2008
  • Marnus Jacobs
    Marnus Jacobs May 08, 2008
    This is simly a factory fault with your lamp. Take it back to the retailer you bought it from , they must replace it with another.
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp.
Use a clean piece of toilet tissue when installing the new lamp to eliminate the above.
Jan 11, 2014 | Sharp XR-10X Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have a Mitsubishi WD-57734 and the picture when out on it. It's 3 years old and seems logical that the bulb burnt out. We still here the sound. I started looking at replacement bulbs and found other...
U used this tv 3 years?The tv been on and watches like 4 or 5 hours every day?Yes,than the tv projection lamp life is over.Require a new tv projection lamp.U also hear alot of cliking sounds,when tv first turn on?Yes,than the Ballast board is also dead.The Ballast board job is to help to ignite the tv projection lamp.
Nov 16, 2010 | Mitsubishi WD-57734 57" HDTV
I turned on my tv and after about 30seconds is sounded like a light bulb blew and the tv went out. whenif is on now if has a crackling in the back intermitently and when you look in the back grill you can...
The tv projection lamp has not been change in this tv the last 1/1/2 or 2 years and been on an watches 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 05, 2010 | Samsung HCM5525W 55" Rear Projection...
After replacing a bulb, when power on, it flash first green and goes to flash red continue to flashes red about 5 flash each time what should i do?
5 is a lamp driver fault, could be a poorly seated bulb or a bad ballast. Usaly it is a bad ballast. Previous bulb failure could have dammaged the balast.
May 07, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
My hitachi 50v720 bulb blew and the replacement doesn't fit
I believe the lamp you need is the UX21516. not the 21517
I have a 50VF820 and this is the lamp for it.
By the way my unit just hit the 3 years and the lamp just blew as well.
Dec 14, 2008 | Hitachi 50V720 Television
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
96 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
