Question about Craftsman Convertible 25cc. Gas Line Trimmer
The pull chord is jammed i cannot remove the part that the cord is wound on in order to unwind it....help please
    President:
  • Craftsman Master
  • 1,545 Answers
Here is a condensed version of getting to the starter/recoil unit to inspect or repair.
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck!
Posted on Aug 29, 2010
How can I remove the roller brush to clean it?
While not removing rollers, my method of cleaning them involves regular attention to prevent build up. Sometimes long hair or threads get wound so thickly & tightly the roller gets stuck & won't turn. If I can't unwind enough by pulling a few threads at a time, I'll cut a bit & pull it away a bit at a time until the mess pulls free. This is especially tedious if it gets caught at the edges in the rotation mechanism. That can be one piece of thread at a time, tugging gently & cutting away the jam until you can free it. As for the brushes themselves, sometimes a wide toothed comb will clear clumps of pet fur & rug lint from each strip of brush on the rollers, making it easier to see & remove long, wound tightly tangles.
Jan 17, 2016 | Vacuums
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
I pulled the pull cord right out of it s hole. So I unscrewed all of the screws to fix it but i cant unscrewed the fans screw ????
There should be no need to remove the flywheel (fans?) to repair the starter cord. The starter mechanism should have come free of the left side housing so that everything you need to deal with is in that package. Did the cord break, or just pulled the cord free of the spool inside? If the cord broke, then buy a replacement cord (about 1-meter in length) of the same size and material (no cotton cord). Thread the cord into the spool center where there is a hole for the inside part of the cord and bring the end out of the hole. Melt the cord end, and then tie an overhand knot in the cord. Pull the knot back tight and proceed to wind the cord in a CCW direction around the spool until you have about most of it wound. Pull on the cord to wind the internal spring several turns and wedge the spool so that it won't unwind the spring. Wind the balance of the cord until you have about 8" left--feed that end through the outer hole and into the handle. Melt the cord end, then tie an overhand knot in it. Stuff the knot into the handle cavity and remove the spool wedge. Try the cord several times to make sure the spring pulls it back firmly and allows ample cord pull-out. Hope this helps!
Jan 29, 2011 | Garden
I cannot pull the chord to start my CS 4210 Troy-Built Chipper/Shredder. Can you help
Can you rotate the engine crankshaft from the drive end? If ok, then remove the starter assembly from the engine and try to pull the cord. If locked, look for mis-wound cord on the spool and try to turn the spool somewhat. Any binding should be quite obvious. Hope this helps!
Dec 19, 2010 | Garden
Brake spring recoil will not open
I assume you are speaking of the starter cord return spring. Make sure to turn it CCW to wind it, but leave enough slack so that the spool can turn about four more turns without binding the spring when starting. If the cord broke, the spool may have over-run it's stops--try to to pull the spool outward when trying to wind the spring. Leave the cord off until you get the spring correctly wound. When wound, wedge the spool to prevent it from unwinding. Be sure to melt the cord ends before tying the overhand knot--but leave the outer end alone until the handle is slipped over the cord. Hope some of this helps!
Jul 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How does the spring attach to the pull cord after you get it wound back up?
The outer spring should attach to the cord spool in a recess or post. Wedge it to keep it from unwinding, attach the inner cord end and thread it around the spool until nearly wound. Feed it out of the cord port and pull the cord out which winds the spring some more. Make sure the cord can reach full extension without binding the spring (don't let go of the cord!!), clamp the cord with locking pliers, and fit the handle. Melt the cord ends to prevent the knots from pulling out and be sure the cord turns the engine in a CCW direction when pulled!!! Hope this helps!
Jun 20, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The rope does not retract when the cord is pulle... how do I fix it
Has the cord been replaced? If so, when the old one broke, the spring will completely unwind. The trick is to rewind the spring first, attach the new cord and wind it around the spool while holding the spring tension. After the cord is wound, feed the end out through the cord port and test for good return (don't let go!!), then clamp the cord with locking pliers and affix the handle to the cord. Melting the cord ends helps keep the knots from pulling out. Hope this helps!
Jun 07, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to replace pull start cord on ms 192 stihl chainsaw
Not that bad. Remove the screws from the starter. Very gently lift it off. Now you will see a grove in the pulley where the starter cord is wound. Fish the cord in from the outside, get it in this grove, wind it a few times in the direction of pulling. Now unwind it to its end. Never remove the screw in the center! Install the new cord, wind it up about 4 turns, poke it out, clamp or tie it from drawing back in, install the pull handle!
By the way, Chainsaws are one of the most deadly of all home tools!
Apr 04, 2010 | Garden
Hoover Windtunnel Tseries cord pulled out too
In the case of where you have decided to "fix" it yourself the best thing is to make small drawings of what goes where as you take things apart. Lay out a white towel and put all the parts on it in the order you removed them. To keep from loosing screws you can screw them back in their holes you took them out of, or lay them in order next to the part you took off. Sometimes there may be longer screws. On your drawings indicate where they go. You don't have to be an artist, just as long as you can understand what you've drawn. As far as the switch is concerned it's either a safety feature or there is a wire pulled part way out and is pushed or pulled back into place when you lean the handle back. Now, understand that there are flat metal "clock" springs that are wound up tight on the part the end is attached to. Whatever you do pay close attention to what is going on just as you begin to open the housing up that holds the cord. If the clock spring is attached to something that may come loose as you pull it apart, it's liable to come off of the winding mechanism and completely unwind suddenly. I've had this happen before. And you never know how many times to wind it up in order for it to be able to pull the cord back in the housing quickly like it did when it was working.
Mar 08, 2010 | Vacuums
How do i untangle the pull cord on my leaf blower, it is jammed inside (210MPH/450CFM Craftsman)
just tack the recoil off they are usually easy to remove do to the nature of the part then you should be able to unwind and untangle. in the future dont let go of the cord until it is wound back up that will elininate the back lash and tangling
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman Convertible 25cc. Gas Line Trimmer Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
