Question about Dell Inspiron 1525 Notebook
I bought a DELL INSPIRON 1525 in august 2008. it worked fine until recently. now the issue is, the battery is not charging. when i plug in, it says "plugged in, charging"...but my battery is stuck at 32% for 3 days now...the battery charging light is ON, even when i shut down and plug in...i checked my battery status and it says the battery is working fine Kindly tell me what to do?should i change the adopter? I'd be grateful
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 29, 2010
MY DELL LAPTOP SAY 0 % NOT CHARGING
Take it back to where you bought it from for testing.
Try putting charger in a different power point.
Dec 12, 2012 | Dell Inspiron 1525 Laptop
I've recently bought a new charger for my dell inspiron 1525. The green light still shines when its plugged in, but it doesnt appear to be charging the laptop itself. Before, i would have put it down...
enter the bios with F12 and battery status somewhere, you have to see if the battery is charging.
1 - if you do not recharge the battery, you can try a new battery if the battery schimnabata no (new) option 2 then it does not load.
2 - is necessary to change the motherboard, because the battery charging mode does not function normally.
warranty if you go to them to do.
Feb 12, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not...
the problem is batteries wear out. You will most likely need to replace it
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
Sep 01, 2010 | Dell Inspiron 1525 Notebook
How long does the battery last, when you use your computer WITHOUT the AC adapter connected?
Did you purchase a 1-year, 2-year, or 3-year warranty?
If the latter, you could exercise the warranty, and get the battery replaced.
Do you have any friends with a compatible laptop?
Does their battery charge to 100% in your computer?
Does your battery charge to 100% in their computer?
Have you looked on eBay to purchase a replacement battery?
Or, there is a company in Seattle that takes your battery,
opens it up, replaces the cells, closes it, and ships it back to you.
This could be less expensive than buying a new genuine-DELL battery.
Sep 01, 2010 | Dell Tablets & eReaders
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell Won't Regonize New Dell Battery
Hi
Need more info
We are talking about the main battery / not cmos battery?
Does charger lamp illuminate?
If so ensure plugs are securely pressed in to Laptop and charger.
If charger lamp does NOT light up try a different wall plug.
Surely Dell would have tested that battery and charging before returning.
Aug 12, 2009 | Dell Inspiron 1525 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1525 Notebook Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
