Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
HP C4180 Carriage Jam
I put a color ink cartridge in my HP C4180 and it jammed. I tried following the online directions to try to slide it and turn the printer off and on to reset, but it would not slide. It is just stuck in by the right side of the printer. I tried plugging and replugging in and there is no paper jam or anything.
Best buy told me that since the printer was under $200, it is basically disposable and would cost too much to fix.
Please advise,as I would hate to have to buy a new printer.
Thank you.
  • Lisa2222 May 08, 2008
    Thanks very much for your help. I will call them and give it a try.
    If I do end up having to purchase a new printer, what would you suggest? What is a good printer that you would recommend for home use? We print A LOT and copy and scan some.
    Thanks for your help. It is VERY MUCH appreciate!!!
you can call HP technical service which is open 24 * 7 and the phone number is 1 800 474 6836 for US customers.
Customers of other countries can open the following link:
There is a high chance of the printer hardware failure. If the printer is under warranty, HP will replace the printer for you.
Posted on May 08, 2008
Carriage jam
Have you tried unplugging from power source then turning back on? Then try run a test page..
Oct 10, 2012 | HP PSC 1610 All-In-One InkJet Printer
I have just replaced my black ink cartridge and it shows allingment failed and my colour cartdige is low
Hi Paul,
I too have a C4180, and am getting Carriage Jam messages. I believe my problem to not be paper jams, but instead glob of ink that have collected under the cleaning mechanism on the right side of the printer. If you look inside you may find the same problem. There are (felt-type) absorbers and mine are soaked with ink, and the also some globs. There is a plastic tray that moves back and forth to clean the ink cartridges and it is no longer moving freely due to the ink.
I am trying to find a service manual to be able to disassemble and clean up properly the dripped ink. In the meantime I have used qtips, paper towwels and alcohol to try to remove the bulk of it.
Try this and let me know if it works for you.
Jan 25, 2011 | HP PhotoSmart C4180 All-in-One Color...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
THe screen is showing ERROR...Carriage jam open
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
Sep 30, 2009 | HP Officejet J3680 Multifunction Printer...
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Try the steps mentioned in the link Bellow:
Also make sure you should Unplug the power cord when there is
still power in the unit, take out both the ink cartridges and apply little more pressure and move the carriage too and fro untill you feel it is moving freely (Dont worry it wil not break)
Good Luck
May 07, 2008 | HP PhotoSmart C4180 All-in-One Color...
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Jam problem
Well, the issue seems to be with Printer carriage stall or it could be an issue with Paper feed rollers or with Communication issue between Computer and Printer.
Please open below web link and try the steps that are mentioned in the web page.
I hope that this should resolve the issue for you.
Oct 15, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
229 people viewed this question
Ben Johnson
