Question about GE Refrigerators
Tcx18paabrww, back of freezer compartment fill up with lots of ice and water runs underneath on the floor
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 22, 2011 | Kenmore Side by Side Refrigerator
Driping of water from top inside of refrigrator compartment. leaving every thing filled with water in refrigrator.
Leo Ponder
imufo2
Sep 17, 2011 | Haier HRF10WNB Top Freezer Refrigerator
Water in the bottom of the freezer compartment, collects and freezes ,fills the bottom with 1/2 of ice. continues and runs out on the floor. LG LFX25975 Where is the water coming from? Doors and Drawer...
Leo Ponder
imufo2
Sep 03, 2011 | LG LFX25975SW (247 cu ft) Bottom Freezer...
I have a frigidaire model FRS24ZRH side by side ....about a 2000 model, and we keep finding puddles of water coming from underneath it. This unit also has frozen ice in the bottom of the freezer, I can...
Good day,
Assuming the temperatures in the machine are normal.
Your drain system is either iced or frozen.
Machine must be off to perform the following.
In the freezer compartment, remove the bottom back panel. Remove what ice you can but use little heat, and no chipping. Real hot water, and lots of towels are best.
Once you get the ice melted out, you will see a hole, below the cooling coil that drains the water to the drain pan. Keep pouring extremely hot water into the hole to see if it will open. If not,
Service techs use compressed air with a hose, to blow the drain open, backward. From the drain hose at the drain pan back into the freezer compartment.
If you have access do as the pros do, but if not, repeated use of an extremely hot water with a weak solution of bleach may get the job done.
I use a tire pump with a 1/4 inch fitting on the end to clear drains,
In either case that will have to be done.
Do not rush this process. Time is your friend here.
Once done, make sure you don't see ice streaks running down the coil. The ice maker fill tube can cause this problem, if it is dislodged.
Should solve the puddles of water on the floor as well.
Thank you for using FixYa
Jan 17, 2010 | Maytag MSD2758G Side by Side Refrigerator
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
