Question about GE WSXH208A Front Load Washer
My front load ge washer model GCVH6260F is leaking past the front door. I have examined the seal and it looks fine. Any suggestions.
    President:
  • 1,197 Answers
The bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE.
New bellows $150 plus fitting so I use a Bike repair it and used the glue to glue a piece of bicycle tube to the inside of the seal to cover the chip by 1 cm either side and trimmed to the same height as the seal lip.
I then placed a little bathroom sanitized silicon sealant over the repair within the chip, wet down with soapy water on the door glass in the chip area and shut the door. Carefully wipe of any excess with wet finger and repeat. Open the door and let it all cure.
Posted on Aug 29, 2010
Door on ge front loader washer leaks, door gasket is fine. Could it be the lock not working properly
Yes it could be the door lock not pulling the door in enough to make the seal. Solution... Remove covers and with door pressed in hard, ( You may need help ), adjust the lock mechanism to make seal. Put lock-tite on the threads after it works for you. This will prevent the shaking of the washer from losening of the nuts again.
Aug 01, 2010 | GE WSXH208A Front Load Washer
Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Feb 03, 2010 | Washing Machines
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
Leaks like crazy. Looks like from under it somewhere and from the door.
Need to look at your seal in the front. I have replaced four of them in the past two and one half years I have owened mine. Do not use it if it is still leaking because there is electronic conrolers under there and if they short out its a prety penny to replace them. I hope this helps you.
Jul 18, 2009 | GE WBVH6240F Front Load Washer
Smell in Front Loading GE Washer GCVH6260F
more likely due to using liquid detergent - change to powder
Dec 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Dec 11, 2007 | GE Energy Star WCVH6260F Front Load Washer
Water leaks through bottom of Front door
The manufactures suggest putting washers on the back side of the hinge to draw the door tighter to the seal, otherwise you may have to replace the seal.
Oct 30, 2007 | Kenmore 44042 Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
151 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
