Question about Samsung Washing Machines
Drains water as soon as i start cycle - Samsung Washing Machines
  • Samsung Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Aug 29, 2010
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Maytag MAH8700 pumps the water out of the tub but then tries repeated to keep pumping water and will not progess to spin cycle. It will do this and then sometimes (not all) display the nd error code.
Edit your posting to add Make and Model#
Check your manual for troubleshooting tips or search online for your make and model# to find a manual.
Contact the company of your product or a local appliance shop to ask them.
May 12, 2015 | Washing Machines
How do I replace the water pump
Not enough information, are you stating when you start the cycle no water enters the tub?
The normal operation at start the washer goes into drain first then starts the cycle.
Jan 07, 2015 | Samsung DMT300RFS Dishwashers : Built in...
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
LG WM2277H Front Load Washer drain pump never stops
Could be the water pressure switch is faulty and/or the electronics control circuitry.
Suggest you called a qualified Technician to fix it. It will be worth it for many reasons.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 23, 2012 | LG WM2277H Front Load Washer
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Dishwasher
make sure the drain hose is at least 20'' above the floor before it goes into a drain pipe. if you have it going directly into the floor it will siphon the water out as soon as it is pumped in
Dec 24, 2007 | Dishwashers
Washing Machines Logo
13 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
