Question about Abit NF-M2S Motherboard
Abit motherboard nf-m2s
Looking for wiring manual to hook up tower to the motherboard purchase new case motherboard dont say what wire goes where,hard drive ,power switch,led ect
    President:
  • 2,351 Answers
Hi chatzmoe, on page 8 of you're manual is a picture & layout for you're abit NF-M2S front panel connectors for LED's.
If you're current manual does not show this, tham download the manual from the link below.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF-M2S&fMTYPE=Socket%20AM2&pPRODINFO=Manual
Main web page for Abit NF-M2S.
Have more questions? Please feel free to ask.
Luck!
Mike
Posted on May 08, 2008
SOURCE:
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
Jul 30, 2014 | Shuttle AK32 Motherboard
Wiring motherboard to a atx tower
The motherboard manual will give you a breakdown of the cast-to-motherboard connections for the board. They differ slightly from board to board, but the connections are almost always found at the bottom front corner of the motherboard. There will be connections for the hard drive LED, the power LED, the power switch, the reset switch, and on some, the speaker (optional). The power switch and the reset switch connectors , 2-pin plugs, are not polarized, meaning that they can be connected to their pins either way without issue. The Power and HDD LED plugs are polarized, as LEDs have a positive and negative. Get this plug backward and the LED won't work. These are also 2-pin plugs. The power LED usually has a green and white wire (Green is +) and the HDD is usually red and white (Red is +) . Some motherboards have color-coded pins -- DO NOT TRUST THEM IF YOU DON'T HAVE A MANUAL -- they are not always standardized. Some motherboards have small print on the board adjacent to the pins to identify them. You CAN trust these. Otherwise, go to the Motherboard manufacturers site and get the manual for the board. The model number is on the board and can be searched for. If the manufacturer's name is not obvious, Google the model number and it will usually lead you to the manufacturer.
Dec 17, 2011 | Intel Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
LED Connections on a basic brand Motherboard
Here is a link to the manual for that particular motherboard.
pdf Manual
Hope this helps
Sep 24, 2009 | IBM Aptiva E 2170 PC Desktop
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Abit NF-M2S Motherboard Logo
5,874 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
