Question about Poulan "Poulan" Push Mower
Where can if i find a replacement air filter for my 21" poulan mower? no one seems to carry them. It's a honda engine.
  • 819 Answers
There should be a model number for the engine stamped on the mower somewhere. more than likely, you will need to buy the filter from a honda small engine shop as opposed to a poulan supplier. if you bring the filter in to your local honda equipment shop, they should be able to match it up quite easily. good luck!
Posted on Aug 29, 2010
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Jun 07, 2014 | Poulan "Poulan" Push Mower
My push mower was stored for over a year tipped up, and all the oil leaked out. It won't start now.
The paper air filter will now be soaked with oil, remove the filter completely, remove the spark plug and crank the engine to evacuate any oil above the piston, clean/replace the spark plug and re fit, top the engine oil up if low, now attept to startbthe engine with the filter still removed, once it starts it will smoke heavily until it clears the oil in the bore.
Mar 04, 2012 | Poulan "Poulan" Push Mower
Poulan Pro 42" with 17.5
you need to find out if there is spark at the plugs
pull the plug put the wire back on hold it away from the engine then crank it over, you should see a nice blue spark arking from plug the engine body
If not then you need the start checking pug , wire , coil, or magneto wich ever your machine has
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Does my lawn mower poulan pro model#PR625Y22RKP have a air filter? where is it?
Just about all internal combustion engines have some type of air filter. Clean air to any engine is extremely important. Most engines always have the air filter located ahead of the carburetor or the fuel injection system. Yours is probably located on the side of the engine under a cover with a screw in it. The cover may look like part of the main engine cover, but it will be smaller. Check on both sides of your machine, just behind the front of the engine.
Jan 23, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Is the air filter on my lawn mower is washable?
You can do both. Just make sure that if you wash it with your hose you let it dry out EXTREMELY well before putting it back on your system
Jun 01, 2009 | Poulan "Poulan" Push Mower
Replace belt on husqvarna R53SV
You may have oil in the air filter after turning it over,Remove air filter and try, if it starts,replace air filter. I had same problem.
Mar 02, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Poulan "Poulan" Push Mower Logo
183 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
