Question about KitchenAid KSBS25IV Side by Side Refrigerator
KitchenAid KSBS25FJWH01 - stopped running - no compressor sound - nothing. Someone said it is probably circuitboard - any start relay switch potential versus circuit board?
  • KitchenAid Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 29, 2010
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
KitchenAid Refrigerator KTRC22KKSS00 has stopped FREEZING. The cooling part works but the freezer doesn't, it's just cooling. The relay is klicking at least 3 times within 5 minutes. I don't have a...
just replace the relay and overload/ptc on the compressor,whats happened is the unit is running on both the start windings and run and overheating due to continued high current demand from the start windings,normally it uses these winding just to start the motor from a dead stop,then they open up via the relay and the run windings keep it running at a much lower current
Mar 15, 2010 | KitchenAid Refrigerators
Help! Our KitchenAid side by side stopped cooling today..both freezer and refrig! There is a clicking sound every few minutes...Any ideas?
You will need to pull the refrig out and remove the lower panel . On the compressor , is a square box ( overload/relay ) . This piece has a plug with 2 or 3 wires , going to it . The part number for the part is 8201786 , and is easily replaceable . Compressors going out , is extremely rare .
Nov 26, 2009 | KitchenAid KSRS25IL Side by Side...
Kitchenaid Wine Cellar-model # KUWS2246EBLO Power on switch does not turn on cooling compressor. Lite will come on.
Try tapping on the thermostat it is probably sticking.
If it comes on then you will need to replace the thermostat.
Check the start relay on the compressor.
Check the fan motor on the compressor is it running?
Clean lint from underneath on the condensing coil.
Mar 26, 2009 | KitchenAid 48-bottle Wine Cellar
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator is not getting cold
pull you refrig away from the wall and look behind the cardboard cover you will see the compressor (big black bowling ball looking thing). we need to determine if it is running you should here a low consistent hum. if the compressor is not running you will probably hear a humming and clicking noise about every 3-5 mins indicating the compressor is trying to start but shutting back down. the culprit is usually the start relay loated on the side of the compressor. this is a plug and play part and very easy to repace yourself get pt#8201786 from whirlpool the good instructions for replacing the part. good luck peyton
Jan 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Humming noise repeats every few min. evaporator fan runs constantly frig still cold
it sounds like a bad:
  •           start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
·                                 so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 15, 2008 | KitchenAid Refrigerators
Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid fridg compressor heating up
If the compressor is very hot, it sounds like it may be locked up. Is there an external fan next to it that is not running. this will cause the comp. to overheat, like a dirty coil, which it sounds like you checked out. There is a thermal overload on the compressor. Its underneath the little plastic cover that the wires go to. It protects the compressor from a meltdown. It also has a relay in there. If you have an amp meter you can check this by waiting for it to cool off and clamp it on one of the compressor wires.when it clicks on, If the amps soar over 20 very quickly, and then stops. Its a locked compressor and the thermal overload is cutting it out. If you don't have a volt/amp meter, then try replacing the relay as its pretty cheap. But I would bet on the comp. as long as the fan is running.
Jan 16, 2008 | KitchenAid Superba Architect KSCS25INSS...
Constantly running
If the thermistor sensor for the temperature control is going out that could cause the compressor the think it needs to keep running to cool the unit. The fan near the compressor should run only when the compressor runs. If the fan is running and the compressor isn't then you likely have a compressor start device problem or the overload is tripping from high heat, etc. That would make the compressor run (or try to) every minute or two if not just run continuously. Make sure all the coils under the unit are clean of fuzzy's and hair, etc. by doing a good vac. clean on them also. The compressor can be slightly warm to the touch but shouldn't be so hot that it is hard to keep you r hands on it for long. If it's around 130 degrees F, then it may be the start device problem and is in an overheat condition.
Dec 09, 2006 | Roper RT21AKXKQ Top Freezer Refrigerator
KitchenAid KSBS25IV Side by Side Refrigerator Logo
91 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
