Question about Microwave Ovens
Frigidaire GAS range model no. FGF355CGBA oven does not heat; stays on PREHEAT mode no matter what temperature is set. What is the problem, can it be fixed cost effectively, can it be fixed by layman?
  • rudolph johnson jr Sep 02, 2010
    Your diagnosis was right on target, it was the BAKE IGNITOR failing; unfortunately I didn't have the expertise nor the tools to do the repair myself, I had to get a repairman. But armed with the information you provided I was able to choose a repair professional who wasn't trying to give me a lot of double-talk and jack the price. He did a good job, in about an half hour or so... he even cleaned inside the oven and the floor under the range which was exposed when he removed the bottom drawer to access the wiring to the ignitor. Bottom line is I am happy with the service and the price the repairman provided, and very happy with the informational service you provided. Only thing more I would've liked is instructions to do the repair [which was really simple seeing him do it]. Again, Thank You! Rudolph Johnson, Jr.
    Solution accepted (please read comments to KAPISHTECH). I'm satisfied, thank you.
  • 2,272 Answers
Your range uses a glow bar ignition system. On that design of range if the oven ignitor is not glowing at all, the problem could be in the thermostat, oven ignitor or oven gas valve (or a wire has just come off somewhere). Each of those components should be able to be tested for continuity to see if one is open (has infinite resistance) or not. If it is, it is likely defective and needs to be replaced. Sounds like your bake ignitor is failing. It can glow cherry red and still be bad. The ignitor must send between 3.2 and 3.6 amps to the valve to open it. To test the ignitor it must be calling for heat and an amp meter put on it to read the amperage it is putting out. If it is not then the faulty is your problem. The cost is near to $45. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 29, 2010
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
Frigidaire Gallery stovetop model number LGEF3031KMB Oven will not heat up to temperature. Oven, Pre-heat lights will come on, but the oven will not reach any temperature set.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 11, 2011 | Microwave Ovens
NEED A OPERATION MANUEL FOR A TAPPAN GAS RANGE MODEL#TGF328GSF
The manaul for the Tappan gas range, TGF328GSF, is available from the Frigidaire site: http://www.frigidaire.com/manuals ; then enter your model number. The direct link to the manual is http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316417139en.pdf . Tappan, Electrolux and Frigidaire are all lines within one company now.
I hope this helps.
Jun 14, 2011 | Microwave Ovens
My oven was bought one & a half yrs ago. Just now i on the oven to preheat & there is no temperature. Just wonder my oven is spoilt? Thanks
Did you mention if this is a microwave or a gas or electric oven.
If microwave there is no preheat unless with the food or using the heater, if so the heating element can be faulty. You will need to check this out and then check with the heating coils to confirm.
Someimes it can be only a fault on the contacts, relay or the connections to the heater.
May 07, 2011 | Microwave Ovens
When I preheat the oven it takes an hour to reach 200 degrees. Is this normal? I am sure it was a lot quicker than this.
An hour to go from room temperature to 200 degrees F (or even C for that matter) is unacceptable.
There is a problem with either a control, sensor or heating element. You should have this oven serviced to restore it to proper working order.
Mar 30, 2011 | Microwave Ovens
How to preheat my new microwave model EM-C5796V of sanyo
you really don't pre-heat a microwave. set it for the time you want to cook and it reaches the temperature for cooking almost instantly
Sep 27, 2010 | Sanyo EM-Z2100GS Microwave Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Convection Preheat doesn't reach the Chosen Oven Temperature
I would first suspect the thermister (thermistor) or a low line voltage, weak control board relay etc.
But the service manuals will show you how to safely disassemble, test and repair the unit.
We have the service manuals for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 04, 2009 | Sharp R-1870 Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
