Question about Dell Microsoft Windows XP Home Edition
I was useing my computer and the screen turned blue and said unable to load windows. it wont strat up again it just keeps going to the blue screen. it will only turn off it i pull out the battires.
    Genius:
  • 1,044 Answers
There is a virus which has corrupted some files and therefore it is unable to load windows. In this case you have to reload windows with the help of CDs which came with the computer. If you had made a start up CD, which is advised, when you purchased the computer, that will be very helpful in this case. The only set back will be that you will loose certain data as everything will be reset to factory settings.
Posted on Aug 29, 2010
Problem with windows starting up with blue screen
Update drivers that control your PC. If problem still persists then use a system utility tool like RegInOut, it will fix the following problems in your PC:
  • Application runtime errors
  • Windows crashes
  • Blue Screen of Death (BSOD)/ STOP Errors
  • Automatic system reboots
  • Failure to start your computer
  • Programs refuse to start
Hope it works for you.
Jan 03, 2012 | Coby 10" NBPC1023 Netbook PC
I have a windows vista which keeps having blue screen and is unable to be turned on sometimes after the blue and i have to wait for a while to be able to switch it on again. any ways to fix it ? thanks
Look at the power settings. The system may be going to sleep, the hard drive shutting down, display blanking by the computer and the monitor itself all can play a part in your problem.
The delay in recovering from sleep in considerable, hybernate is worse, meaning delay.
Oct 08, 2010 | Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Blue Screen Comes and Computer (Dell 1525) Keeps Restarting HELP!
are you using windows? just reinstall your operating system, this may keep it back to normal
Jul 15, 2009 | Dell Inspiron 1525 Laptop Jet Black
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Acer AS5415-2153 laptop has blue screen won't do anything. any suggestions
you have either of two problems or both one is chip set drivers could be bad or the hard drive failed or windows failed do you have a start up disk if so use it to load the computer if it wont load use another computer and download the chip set drivers and install them if that dont repair it try your restore if not that hard drive has failed. just keep in mind these are the most common problems that cause the blue screen sometimes motherboards or CPU's go bad. i have a tester the tells me what wrong in my shop.
Jul 06, 2008 | Acer Computers & Internet
Laptop wont start properly
Have you tried starting in safe-mode?
hit F8 when windows is loading for safe mode.
Nov 18, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
