Question about Dometic Rooftop RV Air Conditioner
I am replaceing my ac unit 630035.321 ac/heat duo-therm low prof.with 641515.301ccc but i had no paper work for install do not need heat on this unit
    Top Expert:
  • Dometic Master
  • 4,292 Answers
Dip switches correct
Posted on Sep 15, 2017
4 Suggested Answers
  • 46 Answers
SOURCE: Duo-therm fan only runs on low
useually a sticking fan relay in the controll board this is the closeest unit to a home based cenral air system and i would leave this one to the experts if you want to trouble shoot there is a detailed wiring diagram on the back side of the pc board cover on the fan and compessor unit it self there is a seperate relay for each speed on your unit make sure getting power to selected relay if not trace wiring and do continutity tests back to themostat
Posted on Aug 01, 2009
motor1258
  • 6674 Answers
SOURCE: have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Posted on Jul 10, 2010
  • 381 Answers
SOURCE: duo-therm heat pump model # 630035-331 Unit
Can you give us some more helpful information-- so we can help diagnose the problem:
Like-- what is the outside temperature?--
Have you been able to get heat out of your heat pump before, at this low of an outside temperature?
And which fan are you talking about-- the inside fan, or the outside fan?
Is the inside coil getting nice and warm-- or just barely warm?
and is there frost on the outside coil-- Can you defrost it, but shutting the unit off until the ice is cleared?
Let us know, and we'll better be able to help you to the next step.
Mack B
Posted on Jan 15, 2011
I have a duo therm model 630035.321. What is the best replacement unit?
There isn't one. Every a/c unit is a piece of junk. Just like your t.v., fridge, and microwave. Buy cheap, replace when it breaks down. It's all luck, so Good Luck!! Best Wishes!!
Jun 04, 2017 | Dometic Heating & Cooling
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
Dometic Duo Therm RV AC makes clicking noise when turned off
The braker is getting weak and needs to be replaced the act should be cleaned as the coils get dirty and make the units work harder
Jul 19, 2014 | Dometic Heating & Cooling
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
I have a dometic duo therm roof ac unit that is low on freon - can the system be recharged?
It is a closed system, (ends are soldered) that said, a heating and cooling guy may be able to install fill valves and re-charge for you, but make sure you get a quote ahead of time. How old is the unit? Not normal for them to need re-charge, and I've seen them work good for 15 years, if maintained properly. Has it been completely cleaned recently?
May 26, 2010 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Jul 20, 2009 | Heating & Cooling
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
243 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
