Question about Kenwood Excelon DDX-7015 Car DVD Player
When I hook up my kenwood 8017 it powers on and says something about a connection error and a connection line and it doesn't go past that
  • 4,924 Answers
First try to remove any media connected on it ...and power it again ...cause it might experience some error cause you have something hooked on it and it is not powered..or has no settings made..
also connect the antenna if it has ..and also make a reset cause it might have previous setting that make it look for some devices..
Posted on Aug 30, 2010
Kenwood tm-732a will not power up. In line fuse looks good, 12v getting to the board. What can I do next?
press around board where power comes in to see if solder connections are weak. where the red and black wires come in, it's 12 volt power to the board its usually a reverse polarity diode, its black with a silver stripe around it, its job is to make sure it wasn't hooked up wrong, you could unsolder it MAKE SURE EVERTHING IS HOOKED UP CORRECTLY, turn it on for a test, if it works find a replacement diode.
Sep 28, 2013 | Kenwood Radio Communications
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
Can i hook up my cd player which is a kenwood cd-323m to a vr507 kenwood receiver
hi,
Yes you will be able to connect the same. Connect the line output of the KENWOOD CD 323M to the CD input of the KENWOOD VR507 receiver using a stereo RCA cable. The picture of the cable is added.
ok
Sep 12, 2011 | Kenwood VR-507 Receiver
I cannot get the auxiliary to work on my kenwood kdc- mp235, what do I press to make it work
Most head units come w/ connections for both auxiliary units (for an amp, etc) and the line for the power antenna. in the past when my deck would stop sending a signal via the auxiliary, I would simple use the power antenna. It pretty much just lets the amp or whatever know when to turn on. Separately however, most newer decks have a way to turn off the auxiliary via the menu settings. I might start w/ that if your kenwood happened to be a newer deck.
Aug 28, 2010 | Kenwood KDC-MP235 CD Player
The amp.
check power fuse make sure it's not blown and gettin proper 12 volts if all connections are properly fixed maybe get it checked out
Jun 06, 2010 | Kenwood KAC-8104D Car Audio Amplifier
I am installing a kenwood cd player in my vw jetta. I can't get the cd player to turn off when I turn the ignition off???
Your Jetta has two power feeds, one is always live and one is switched.
Unfortunately the color of the wire sometimes varies by model or year so I can't tell you which one.
I assume you're using an aftermarket harness that you've spliced to the kenwood harness. If it came with documentation (the harness), it should tell you which feed is always live and which is switched. if not you can test the leads with a volt meter when the car is on and when it's off.
You most likely have your power line on the Kenwood deck hooked to the line that's always live. Find the switched line, and connect that one instead. Should work.
Sep 23, 2009 | Kenwood Car Audio & Video
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood Excelon DDX-7015 Car DVD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
