Question about Dryers
E68 error code - Dryers
  • 4 more comments
  • Jodi111 May 13, 2008
    My frigidaire dryer (model AEQ600ESO) keeps getting error code E68. The information I have found states that it is a button stuck----checked all buttons -buttons look ok- keeps on getting error and beeping??
    Another issue is that the time of drying will get stuck on the dryer even when you cancel the dry time keeps showing up on the display and it wont shut off?
  • Anonymous Sep 12, 2008
    Same problem but with Frigidaire model LEQ2152ES0
  • Anonymous Jan 23, 2009
    I have the same problem with my dryer. It is a AEQ7000EG. I have disassembled to the printed circuit board, examined the components and do not see an issue with the button itself. I double-checked all the wires and verified the harnesses are connecting snugly. Any suggestions?
    Thanks,
    johntmerri@bellsouth.net
  • Ronald Keehn Mar 15, 2009
    I have a Fridgidaire gas dryer model # AGQ6000ESO that runs for a few seconds then stops and shows error code E68, The buttons seem to work OK. Should I take the top off and look for a stuck button or relay? Or should I just order a new control assembly. This unit is about 2 years old. Thanks, Ron
  • scubajunky Apr 10, 2009
    Same deal e68 beeps and shuts off tried messing with the buttons to no avail.
    The drying level buttons works and then it does not. the machine keeps powering up by itself.
    this is a POS machine
  • Anonymous Apr 11, 2009
    we have a Frigidaire dryer approx 2 yrs old in our vacation home and it keeps coming up with a code 68 after running just a short time......checked for stuck buttoms...don't know what elsel to do ???
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 08, 2008
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Was receiving E68 code on
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Posted on Aug 17, 2011
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
What is Frigidaire gallery dryer code e68
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Feb 13, 2015 | Frigidaire Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
Error code e68
Good Afternoon Friend,
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Error code 68
Good Morning Mua_m7,
I see that you are having trouble with your Frigidaire washer giving you an E68 error code. The E68 could be one or both of two possibilities.
First, it could be the heating element. If the heating element goes out, this means that you would be unable to get the water temperatures to hotter temperatures.
Second, it could be something going on with the main control board inside your washer.
With you receiving the E68 error code, I suggest that you give your washer a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. When you restore the power, if you are still receiving the E68 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire Washing Machines
E68 error code
If it's a Frigidaire, It's a failure of the touchpad control.
Jun 12, 2012 | Washing Machines
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Cause:
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Dec 29, 2010 | Microsoft Xbox 360 Console
Dryers Logo
922 people viewed this question
Top Dryers Experts
