Question about Radio Communications
Radio squeal in am radio when out on the hi way , ok when park brake is applyed and stoped. loud squeal and whisle in am radio in a 2007 freightliner s/t power unit . someboby please help''''' saskatoon
    Genius:
  • 1,274 Answers
Hi saskatoon, my name is John. Sounds like you have a mic. wire off the plug or loose.First try another mic. If its OK, then its the mic. Unscrew the mic plug from the radio, then remove the two(2) tiny screws at the end of plug, and one (1) tiny screw located about the middle of the plug, then carefully slide it backwards to expose the wiring, observe the wiring, if any wires are off, re solder them.........hope this was very helpful....
Posted on Sep 01, 2010
Brakes make a whistle noise when applied and sometimes a low grown or grinding when coming to a slow stop or start.
A grinding or rumbling noise can also be symptoms of a wheel bearing or constant velocity joint in a driveshaft. A worn wheel bearing can also cause a 'whistling' sound (as can a worn CV joint).
A grinding noise with brakes is either worn pads causing metal to metal contact on the brake disk/rotor, or the brake backing plate catching on a spinning rotor ... or a loose/missing anti squeal brake shim (they stop the pads from rattling and vibrating).
However, as you say a mechanic has looked at the brakes and can't find anything wrong .. I think I would begin to suspect a wheel bearing or constant velocity joint on the driveshaft (front wheel drive cars).
May 05, 2016 | 2007 Honda Accord Sedan
Ira brakes made loud squealing noise car barely moved abs light on put in reverse it lurched then the abs light went off now it's ok what hae need
Check for metallic contamination on the ABS sensors behind the hubs. Also, check to see if your parking brake is hanging up.
Feb 15, 2015 | 1997 Buick LeSabre
Brakes have been squealing off and on, but now has sudden loud scraping noise while driving
Brake shoes/pads worn out. Replace now. Be careful dangerous situation
Aug 13, 2017 | 2000 Suzuki Grand Vitara
Brake Shoe Self-Over-Tightening?
Type of brake shoes there using, the more metallic compound on the shoe will make them Squeal and just takes time for the brake shoes and drums to wear there self to a point where they will not squeal any more. The high Metallic brake shoes will last longer but make more noise, I did a break up grade on my Jimmy with ceramic brake pads and vented rotors. At first before there were broken in, stopping distance was bad and brakes was loud, but now it's like dropping an anchor LOL. Keep me posted and give it a few miles of stop and go traffic.
Jan 11, 2010 | 2006 Pontiac G5
My brakes squeal loudly when backing up and
there is a little piece of spring steel that act`s as a warning when your brake pad`s get low the pad does not look completly worn out take the tire off and double check them or take it to a mechanic you can trust to check them
Oct 25, 2009 | 2007 Nissan Murano SE
When I apply the brakes on my '02Dakota only the forward brake shoe moves against the drum. Have replaced wheel cylinder but makes no difference. Both shoes move when I loosen adjuster cable. Have this...
you mean parking brake cable? loosen parking brake cables put drums on , and adjust shoes till they lightly drag, now apply brakes a few times and check the adjustment again, if all ok, now adjust park brake cables, you want to adjust so park pedal goes 5-8 clicks till the wheels are "locked up" and the wheels spin free with the park brake off
Oct 18, 2009 | 1992 Dodge Dakota
Loud squealing
sounds like shims on brakes, or lack of them
thin bits of metal to stop squeel
Jul 08, 2009 | 1997 Chevrolet Blazer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Unintended acceleration when the brakes are applied 2001 pathfinder.
Hello and my name is john and i will be helping you to day.
Q.
Occasionally your 2001 pathfinder will accelerate when the brakes are applied. And there is a very loud squealing of the tires with the lunching of the car.
A.
Your pathfinder has a TPS sensor which is your throttle position sensor if this sensor is stuck or bad it will send a MSG to your computer saying that it's not getting enough fuel so it will compensate and cause your engine to rev unusually hi and causing your tire's to chirp also your apm's should jump while doing that you should se a big difference in your gas mileage as well.
Oct 11, 2008 | 2001 Nissan Pathfinder
Radio Communications Logo
106 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
