Question about Garden
Replace fuel line homelite xl 12 saw hard to pull new line through hole in tank
  • 398 Answers
SOURCE: Hole at top of fuel tank
yes two tube always go into the gas tanks. you should be able to find the connection were that tube is suppose to go. if you have a tube in the tank with the filter on end you know it(the missing fuel line) just needs a atraight tube into the tank from a barbed port(were the other end hooks to). let me know if you do not understand.
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: 23cc weedeater fuel line to filter in tank is rotten
1st get new line. find where it goes on carb. pull the line out of the tank .cut a pc. of new line longer then what you need ,cut the end of the tubing with dia.pliers at a long angle then push it into the tank untill you can fish it out hook it back to the filter pull the extra tubing back towards the carb. leaving the filter at the bottom of the tank
Posted on Jun 18, 2009
moretons
  • 155 Answers
SOURCE: The fuel lines have rotted out of the edger gas
no you can buy replacement fuel line but you must reconnect the filter in the tank that line goes to the bottom of the carby then out the top of the carby to the inlet on the primer then out of the primer and back to the tank.
Posted on Jul 25, 2009
  • 138 Answers
SOURCE: Homelite ST-185 (15039A). Route new fuel line.
If you look closely there should be 2 holes in the fuel tank, also if you look inside the fuel tank there should be some remaining pieces of the fuel line and a fuel filter. If this has been sitting for any length of time you will also want to replace the fuel filter.
Now comes the fun... or a challenge
To start with you will need 2 sizes of fuel line ( go to a small engine repair shop) while you are replacing things you may want to buy a new primer bulb also.
to insert the fuel lines into the tank you will have to cut a tapered tail about 2 " long so that you can grab the fuel line with a needle nose and pull them through and out of the tank so that you can trim off the tapered tails. On one install the fuel filter and stick back into the tank, on the other trim the tapered tail off and pull the line back into the tank but leave about 1" sticking through the tank.
Now hook up you fuel lines to the carb and/ or primer bulb
Fill tank half full with fuel ... now test the installation if it doesn't pump fuel but instead you can hear it blow bubbles in the tank it is simple just reverse your lines on the carb / primer bulb
Retest if it works like it should you are ready to attempt to start it... good luck
Posted on Sep 09, 2009
  • 279 Answers
SOURCE: Fuel line connections for Homelite S-185
Put them one way and if that doesn't work, exchange them. Good luck...Lee
Posted on Nov 24, 2009
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
My Homelite Mighty Lite has developed perished fuel lines. (12 months after purchase!!!!!!) Is it possible to obtain spare fuel line.... preferably attached to a new fuel tank as well. It looks like a...
The fuel lines can be purchased separately usually by the foot from any outdoor power equipment dealer. They can be easily installed by cutting one end at an angle and "feeding" it through holes. Homelite fuel lines are of a different OD than most so make sure you get the proper size. The most popular size for Homelite is OD .203 ID .04.
Feb 12, 2011 | Homelite Mighty Lite Lawn Trimmer
My chain saw 14" homelite
primers pull fuel from the carb and dumps it back into the tank, so if the bulb will not prime the chances are the fuel filter in the tank is blocked, pull the fuel hose through the filer hole and replace the filter on the end.
Jan 27, 2011 | Garden
Homelite chain saw fuel system
The line at the back of the tank gets the filter (check it for plugging) and the one nearest the cap doesn't use a filter (it is the return line from the primer bulb). The filtered line goes directly to the carburetor inlet port and the outlet port allows fuel to be pulled through the carburetor and out to the primer port. Check and replace any fuel lines that are in poor condition. If the engine has been running with the intake filter missing, the interior of the carburetor may be full of debris. Remove, dismantle, and clean the carburetor interior. Go to: http://www.drystacked.com for an excellent 12 page article on Walbro carburetor theory and troubleshooting. Hope this helps!
May 31, 2010 | Homelite ZR10926 16 Chain Saw
Need parts breakdown for walbro carb from my hb18010c homelite blower.does it make a diff. which line from fuel tank goes to either carb fitting with primer bulb??also have 2 xl-12 saws made in port...
Yes it makes a difference, you ALWAYS draw fuel through the fuel filter as it typically has a check valve but I strongly recommend that you do not buy parts for this carb, they are super sensative and inexpensive, buy a new one and save yourself hours of frustration.
May 25, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 27, 2010 | Homelite Garden
Sep 08, 2009 | Homelite Garden
I recently bought a 12" homelite xl textron chain saw @ yard sale. it runs good but leaks gas. it has a hole in top of gas tank, it looks like a factory drilled hole with nothing in it. is this hole for...
I dont know where the fuel is leaking from but i`ll make a guess and say the fuel lines are perished.NOW all you have to do is disassemble it taking note of where every thing goes and replace them ALL.... not hard just have a good look at where things go before pulling them apart , you will manage
Aug 25, 2009 | Garden
Fuel Line Deteriorated
the piese on the end of the fuel line is a pickup filter. if you can blow thru it, then it is still good and you dont have to replace it, but if you want to, you can get them and the fuel line from your local small engine shop. if you have a menards or home depot in your area they ussually carry the line & filters aswell. you will need to take a piese of the old line with you, so you can match the size. the line going into the tank usually seal due to the hole being smaller than the plastic hose, which makes feeding it interresting. i just heat a 1/4 inch or so of the end just enough to stretch it out. this causes the diameter to shrink,then melt the tip& roll it into a point. as you feed it thru, use a couple drops of oil so it pulls easy and does'nt stretch(which will effect the seal). pull enough hose thru so that the filter will lay flat in the bottom right hand corner (as looking from rear of saw toward the tip of the chain) of the tank. this ensures that you pickup fuel when you tip the saw on its side.
Feb 27, 2009 | Homelite Garden
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
