Question about GPS
Can not get gps set up. having a hard getting system to operatealso
  • 944 Answers
Please specify the model no of your GPS device and brand name,So i could help you more correctly.
Since you have not specified any thing i would give you the basic document to set up the GPS.
Click here for GPS set up guide
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Aug 29, 2010
Setting the clock in a 2006 Jeep GC w/ navigation system
Yes this is a little confusing!! It is set from the Nav window. Depress Nav and scroll down to clock.
Depress clock and you can daylight savings option or set clock
Hope this helps?
Other Jeep Radios
1. Press the MENU hard-key on the right side of the
radio.
2. Then press the System Setup soft-key to get to the
System Setup menu.
Set the Time
1. Press the time soft-key in the lower left corner of the
screen.
The minutes are set by the GPS system.
2. Press the Set Time Zone soft-key to change to the
desired time zone.
3. Press the Daylight Savings soft-key to switch Daylight
Savings on or off.
It is possible to set up your own time (ahead or behind
actual GPS time), by pressing the USER CLOCK soft-key.
NAVIGATION 15
Nov 08, 2016 | Jeep Cars & Trucks
Tip
Problem: My Magellan Triton GPS Does Not Attach the My PC.
Problem: My Magellan Triton GPS Does Not Attach To My PC.
Solution Applies To: Magellan Triton 200 300 400 500 1500 2000 and Windows Operating Systems XP, Vista (32 and 64 byte) and Win7.
Author Note: This is a problem that can happen to any user. This test will confirm that your GPS is not the problem but that the problem lies in the installation of VantagePoint or the Windows Operating System.
Testing Procedure:
The trick is to first make sure that you can attach the GPS to the PC.
This test is simple.
uninstalled the VP and delete the c:magellan drivers directory. Go into c:program filesMagellanVantagePoint and delete the VantagePoint directory and all its subdirectories.
Now do a hard reboot. This is where you completely shut off your computer.
Reinstall VantagePoint 1.94.[You can find this program on my website http://www.jungleghost.com]
After the installation do another hard reboot. This will set up your registers.
Now look at c:magellan drivers to make sure that the directory has been recreated. Go to VP LITE ICON on the bottom of the screen do a right click and uncheck the Lite start up at boot and QUIT.
Now so another hard reboot.
NOW FOR THE TEST.
With VP TURNED OFF and no other Magellan Programs running. Attach the GPS to the PC and turn it on and select under MENU>>VIEW>>SETTINGS .. Connection "Connect to PC". [You may have this choice when you first start the GPS and it is attached to the PC.]
If you CANNOT CONNECT at this point to the PC then you have a corrupt ID software on the internal memory.
If so, return to the unit to the dealer or Magellan, it is defected.
If your unit is out of warranty please visit our Triton Repair Center at http://www.jungleghost.com/repair_service.shtml
JG
on Dec 08, 2010 | GPS
When i turn my gps on the little circle thing that spins make one and a half resolutions and stops and thats it !i did nothing else to it thats why i am on here asking why its doin this and how to fix it!
Solution 1. BACKUP ANY RELEVANT DATA THEN REINSTALL YOUR SOFTWARE FROM THE FLASH DRIVE Instructions: The disk that came with the unit should have a setting to reinstall the software on the GPS. That will make a fresh software install. I am familiar with mio pocket, and with magellan GPS units. You should just be able to plug it into the computer and access the flash drive Solution 2 please try a hard reboot. Hold the power button for 10 seconds or until it reboots. If this does not fix what was changed here is what you need to do Solution 3 It sounds like your programming is off, This means that you can try using the disk to reset it. If that doesn't work then you can go to the website, download the latest firmware, then replace the files you have with the latest firmware. You MAY have to do this manually but it's not hard. I hope this helps and please post if you have any more questions about this. Solution 4 You MAY ALSO TRY THIS FOR A HARD RESET is you keep getting the same SPINNING ERROR Here is how to reset your 1340, 1440, or 1470: Go to the system menu: On the menu bar ( the top bar where it says Sytem Settings) Tap left corner twice, right corner twice, left corner once, right corner once. It will bring up a hidden menu. The first thing on the hidden menu is reset for first use. Press that and you have done the equivalent of a hard reset. Solution 5 SETTINGS Turn off the GPS and turn in back on. Access the Main Menu and select restore all settings to factory defaults(You will loose all your settings and maps once you do this). Any modifications done will be erased automatically OR As for the Settings->Access the Main Menu-> Tap on settings-> Then tap on the option->Restore all default settings.
Jan 13, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Unit locks up after start up and has to be re-set - it doaes this every day when I set off.
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Mar 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
Format my gps usb restart show logo and restart
Well to avoid this problem you can do a hard reset, that reset set all the settings to factory default and it again format in fat file system, Turn the unit off. Hold your thumb on the bottom right of screen and turn it on, keeping your thumb there. Say "Yes" when prompted. Please post comments if further you have the same problem......
Good Luck!!
Thanks
Feb 15, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Does not save, i change something turn it off and when i turn it on its back to the way it use to be
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior, like not being able to save your settings, is an indication that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Nuvi 265WT Manuals here.
Jan 23, 2010 | Garmin nuvi 265WT Car GPS Receiver
I have been having trouble with my roadcom sat nav, I used it to get somewhere and had no problems but when I went to turn it on to come home, the main screen comes up but it just freezes and it wont let...
To hard reset the unit turn the unit off, hold down the mode button and turn the unit on. When the unit asks if you want to erase all user data, select yes. After resetting the unit, leave it with a clear view of the sky for about 30 minutes to acquire the satellite almanac. “ Do not worry You don’t loose Your saved rides data, only all screen settings and some other device settings will go away. Set it back to Your preferences and You’re done. Hard reset is suggested after software updates. In my case it heals all self shutdown problems in my Edge 705 GPS.
Dec 02, 2009 | Garmin Edge 705 Satellite Navigation...
System is not turning
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
Nuvi 265W Manuals here.
Oct 01, 2009 | Garmin Nuvi 265W GPS Receiver
All of my Nuvi 200 settings (recently accessed, favorites, etc.) suddenly disappeared. When I entered a new destination address, however, it still worked. What would erase my previous settings?
I can help you fix your Garmin Nuvi 200W.
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
There are three steps to take to get your Nuvi running like new:
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 265w
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
I hope that helps.
Dec 25, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
21 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
