Question about Kenwood Audio Players & Recorders
We have a 3 way speaker system JL-850W but have no wires or anything for it. Just the 2 speakers itself. Can you help please? I have sent you all the info on it. Woofer 15" (381 mm) Cone type Mild-range 4-1/2" (110 mm) Cone type Tweeter 2" (50 mm) Cone Type Impedance 8 Ohms Maximum input power 180W Rated input power 90W Sensitivity 92 dB/W at 1 m Frequency response 35Hz, 5,000 Hz, Dimensions W: 17-3/8" (442 mm) H: 31-1/2" (800 mm) D: 13-1/16" (331 mm) Net weight 38 lbs (17.3 kg)
  • 52 Answers
All you need is speaker wires or lamp electrical wires. Go to your local hardware store and ask for 16/2 AWG wire
Posted on Sep 01, 2010
Jl w7 not loud enough
If your sub isn't loud enough you may want to look into a few things;
1. What type of amp you're using and its output rating
2. The gauge of your power, ground, and speaker wiring
3. The condition and type of enclosure you are using
4. Check to make sure the speaker cables don't touch, because this can cause it to ground itself out and produce little to no sound.
5. Check the RCA connections and make sure they are in order
Aug 31, 2012 | Jl Audio 12W7 Car Subwoofer
Jl audio 12w3v2 sounds like its blowing air out of box
if you cant see a physical cut or **** in the rubber surround or anywere else you can try to check the wires going from the plug to the actualy speaker itself on the back of the speaker if those are fine then its probably blown if its not that old you can try and contact jl and see if they will replace them i know kicker has some kind of replacement system in play not sure of jl
Feb 28, 2010 | Jl Audio 12W3 Car Subwoofer
Jl audio w7 13 subwoofer system 3ohm driver bridge it 2 ch amp
How much is your speaker max wattage?
If it is 750 or below, it can only be used on one channel, either the right or the left.
If speaker can handle 1500 watts then hook the positive speaker wire to R+
Hook black negative speaker wire to L-
Now it is bridged
Aug 19, 2009 | Jl Audio 13W7 Car Subwoofer
I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
May 26, 2009 | Jl Audio 12W0 Car Speaker
System cutting out
Pull the subs out of the box and check the connections... Check to see if the wires running from the connectors on the sub itself to the voice coil... had a JL 10 that had a frayed wire to the voice coil system would cut in and out. Hope its helpful
Mar 30, 2009 | Alpine SWS-1240 Car Speaker
The magnet on my JL W7-3 came off. I dont know how it happened. I tried to put it back on an now it wont move. Can ne one help me out? Please.
the coil of wire inside the speaker has seazed up, u can either replace the speaker or send it off to be re-wired.
pleasr rate this advice.
Feb 22, 2009 | Jl Audio CLS113RG-W7 Car Subwoofer
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
JL 500/1
It sounds like you have a broken output filter inductor in the amplifier. You should be aware that the speaker outputs of the amp are biased at ~40v DC and can give a good shock if you touch the speaker wire while you're grounded (touching the body of the vehicle).
When you connected the speaker as you did, I would have expected the speaker to move in or out and remain there while the wire was connected to the housing of the amp. I'll assume that the amp was screwed down to the chassis of the vehicle. If it wasn't, you may have more than one problem.
Oct 18, 2007 | Jl Audio 300/4 Car Audio Amplifier
264 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
